help with death wobble
Ok so here's the skinny! I have an 81 with a 22r that I just did rears up front on. Before the swap I had a little wobble up front nothing to write home about. So I have already changed tie rods and today I replaced the drivers side wheel bearings. The wobble starts at thirty mph and its bad enough you can't hold the wheel. The only thing not hooked up is the front drive shaft and that's because its not long enough now. I wouldn't think that would matter since the shaft doesn't turn unless the hubs are locked. I would greatly appreciate any help or advice cause I'm running out of ideas. Thanks in advance.
check to make sure your steering arms are tight, i mean the four studs that come from the knuclke that the steering arms are bolted to, these can come loose over time and cause exactly what you are describing, when you did rufs it probably changed your caster a little bit exacerbating it. also check the drag link for excessive play. oh and snug the crap outta your shackle bolts
Thanks. I will check the shackle bolt and knuckle studs. I am taking it to get it aligned so hopefully that will take care of the caster angle. The draglink and all the steering arms are tight.
Caster is too positive, meaning when you turn, your wheels turn at a really positive angle and the sides of your wheels aim at the ground.
Pretty much a main cause of death wobble.
Might check to see if you put your RUFS on right, because iirc the spring eye bolt is offset. Or it might not be.
Either way, check the offset of the spring eye bolt, and if it's centered up, buy some caster shims to correct the problem.
OR.
Get longer shackles in the front.
OR.
So is the caster corrected by getting an alignment or is that something I can do? I'm not sure what your talking about with the offset springs. I don't remember there being a difference in the springs. I have 6 in shackles all the way around already.
The spring eye bolt can be offset more towards the front or rear, depending on the spring. Some springs have the spring eye center bolt more towards the front.
Anyways
The problem you have if your diff pinion flange is actually pointing at the t-case, is that your caster is too positive.
An alignment would help a little, but you need shims to bring the caster back down to a range more manageable...
These are caster shims. They sit inbetween your axle spring perches, and your leaf springs themselves, and tilt the axle in a positive or negative direction.
In your case, you want the caster more negative, with the pinion flange either at 90* (straight up and down on the flat surface), or slightly negative (to compensate for axle wrap under load). Most of the time a shim won't correct this.
Do you have any pics of your front axle, springs, and front spring hangers?
Anyways
could be tires too, looks like hes got some 35x14s lol
And i think he put his springs in backwards.. with the spring eye bolt more towards the firewall.. Causing a super positive caster.
I will take some pics in the morning of how everything is set up.
So after looking at it some more the only thing out of the ordinary is that the two c clips that go on the leaves to keep the from shifting are missing on one of the leaves. Could this be the culprit? Either way I think I'm gonna take these off and put my old springs back on until I can order some trail gear springs or all pro springs.
well you have hit on a few things.
-check alignment (1/16" tow in)
-spring shackels are tight/snug with good bushings
-high steer is hooked up to the correct holes on the pass side arm
-caster angle (if rear is sagging then the front will be effected)
-also try different tire pressures
Do you have to move the high steer box forward from the original mounting position to correct the angles.
As far as the passenger knuckle I have the rod that comes off the pitman arm straight into the front hole then the arm that goes knuckle to knuckle in the rear hole. Thats correct right?
potatopants
09-15-2015 06:26 AM
lfcarrion3
07-18-2015 04:05 PM
