Dual twin stick ?
Do you mean, dual twin sticks as in having triple cases and the rear two cases twin sticked? You can only have a twin stick in the rear. The purpose of a twin stick is to be able to select 2wd and 4wd independently of low and high range so you have the option of 2 low low. The front cases are only for choosing low or high no matter how many you have.
Having that attitude won't get you any help. Just ignore the people posting stuff you don't like and just be thankful for the help you did receive. Your question was answered, but when you ask a question that normally when you're at the point of putting twin sticks in you should know, people will give ya a hard time
Judging by the questions you are asking, you will definitely be the one needing help on the trail. You should watch your attitude because you will likely be the one not getting it.
Smart asses that know what a twin stick is and and how it functions.
http://www.trail-gear.com/shifter-dual.html
Lighten up Frances.
Sponsor
Twin sticks and dual cases are 2 different things..... you can have Lo/lo... thats the beauty of dual... COMPOUND LOW!
you can also have twin stick with only 1 tcase...
correct me if i'm wrong but... _without_ the twin sticks but dual cases you have have
2wd hi
lo /hi
hi /lo
lo/lo
the twin stick allows you to disengage your front or rear.. to allow for front or rear digs.
2wd hi
lo /hi
hi /lo
lo/lo
2wd hi
lo /hi
hi /lo
lo/lo
2wd hi
lo /hi
hi /lo
lo/lo
Oh I know they're totally different, I'm about to put my dual case setup together here and was just wondering if it was ok to run the first case in low (2.28:1) while having the rear case in high 2wd? Or would that mess something up with crazy RPM's or somethin in the rear case?
Sound like there are more SMART AS_'S then people that want to give helpfull advise.......hope ya'll do need help on the trail.
