Dual twin stick ?
I have everything i need to do my dual t-case conv. My question is....can I put 2 dual twin stick in it.....will it fit ?
2 twin sticks?
Why would you do that, its not possible. Only the rear you can put twin sticks in, the front case just has one function hi/lo. |
I would suggest doing some research of what a dual case does first before you hurt yourself. That will help you determine if you can use two twin sticks.
If you're asking this question you don't understand what a twin stick does. You need to do some more homework.
:guitar: |
Do you mean, dual twin sticks as in having triple cases and the rear two cases twin sticked? You can only have a twin stick in the rear. The purpose of a twin stick is to be able to select 2wd and 4wd independently of low and high range so you have the option of 2 low low. The front cases are only for choosing low or high no matter how many you have.
Let us know how that twin sticked front case works out for you :chair:
You can mount a twin stick on the front case, but only one of the shift levers will be functional.
Sound like there are more SMART AS_'S then people that want to give helpfull advise.......hope ya'll do need help on the trail.
Originally Posted by toyota tom
(Post 51186836)
(Post 51186836)
(Post 51186836)
Smart asses that know what a twin stick is and and how it functions. :hillbill: http://www.trail-gear.com/shifter-dual.html :guitar: |
Originally Posted by waskillywabbit
(Post 51186860)
Lighten up Frances. :roll:
Twin sticks and dual cases are 2 different things..... you can have Lo/lo... thats the beauty of dual... COMPOUND LOW!
you can also have twin stick with only 1 tcase... correct me if i'm wrong but... _without_ the twin sticks but dual cases you have have 2wd hi lo /hi hi /lo lo/lo the twin stick allows you to disengage your front or rear.. to allow for front or rear digs. |
Originally Posted by Tofer
(Post 51186906)
Originally Posted by 89silverpu
(Post 51186920)
Oh I know they're totally different, I'm about to put my dual case setup together here and was just wondering if it was ok to run the first case in low (2.28:1) while having the rear case in high 2wd? Or would that mess something up with crazy RPM's or somethin in the rear case?
Originally Posted by 4Crawler
(Post 51186943)
That is indeed 2WD low range (2.28:1), I use mine all the time. It is no different than the speed/RPM you get in normal 4WD low range, 30-35 miles per hour is top speed.
Sound like there are more SMART AS_'S then people that want to give helpfull advise.......hope ya'll do need help on the trail. |
So....the front single stick is for HI-LO
the second "drivers side" stick is for 2wd-4wd the third "pass side" stick is for ? |
(Post 51187722)
Dual cases with a twin stick
Front case - one stick - H N L Rear case - twin stick - right side - 2WD 4WD ; left side H N L :guitar: |
