a/c leaking inside cab
Assuming you are talking about the condensing water dripping from the A/C evaporator inside the truck (was not clear in your post), it is probably a clogged drain tube. Clear it out and see if that helps. I have a writeup on doing that (not on a Toyota, though) on the web page below:
- http://www.4crawler.com/Diesel/Cheap...ml#ACDrainTube
did some investigating im pretty sure its coming out of the heater core,which im pretty sure is inside the black box to the left of the air damper, anyone had this happen to them?
Yes, I have. I went to local pick and pull got a new core, couldnt figure out why it leaked (what failed). But the used one cleared up my troubles.
Road Bull
10-10-2015 04:55 PM
icentropy
07-14-2015 10:23 AM
