1991 Toyota Pickup rearend
Old 01-10-2011, 03:29 PM
Cpt_Buckout's Avatar
Where can I find a good used rearend for my truck?
Old 01-10-2011, 03:35 PM
MudHippy's Avatar
Car-Part.com
Old 01-10-2011, 03:47 PM
camo31_10.50's Avatar
Local Junkyard will be easiest.
Old 01-10-2011, 03:51 PM
Thanks, I'll try it.
Old 01-10-2011, 04:18 PM
2DoorRunner's Avatar
Craigslist. Wrecking yard.
Old 01-10-2011, 04:28 PM
xxxtreme22r's Avatar
this and other toyota forums classifieds where people are parting out their trucks.
before you ask, I am 90% sure you are looking for a 4cyl 4.10 ratio 8" rear end aka 3rd member.
Old 01-10-2011, 04:55 PM
What all year pickup rearends will work?
Old 01-10-2011, 04:58 PM
79-95 and it has to be a 4wd, 2wd rear ends were 7.5" but you might want someone else to confirm me. Has to come from most likely a manual trans truck as well.
On your door jam area there should be a sticker or plate there that says an axle code, look for the same code. It should look something like G292. I am not up on my axles codes to tell you what your is. Heck I dont even know what mine is off-hand which should in all actuality be the same as yours. And every single time I look for them I come up with this page http://www.off-road.com/toyota/tech/other/4_axles.html which no longer exists.
I am pretty sure that a v6 rear end is also a drop in fit but I am not 100% sure on that. Although it's not 100% the same as the 4cyl 3rd.
Old 01-10-2011, 05:12 PM
jsn_stockard's Avatar
Where are you located Buckout?
Old 01-10-2011, 05:14 PM
I live around Marietta, Oklahoma but I'm working in Little Rock, Arkansas right now.
Old 01-10-2011, 05:18 PM
Ohh snap, you are about 15 minutes north of here. I came across one last month, I will call the guy for you as soon as I get home tomorrow
Old 01-10-2011, 05:21 PM
Ok, thanks much.
Old 01-10-2011, 05:34 PM
Also check out this place for parts. I have used them a few times and had pretty good luck. Is the axle bent or the gears just trashed? If its just gears I would just swap the 3rd member
Toyota Heaven
6723 Oakcrest Dr East
Fort Worth/Kennedale,TX 76140
USA
Ph: (817) 563-1744
Ph: (817) 563-1754
E-mail:frs@toyohv.actual-america.com
Old 01-10-2011, 05:40 PM
MudHippy's Avatar
Any 84-95 4WD PU rear axle, or 84-89 4Runner rear axle. 79-83 4WD PU isn't the same width, nor is a 90-95 4Runner(not to mention the coil springs not leafs). Auto or manual, V6/Turbo or 4cyl, makes no difference. The other important detail though, driveshaft compatability. Generally there's a driveshaft bolt hole pattern that's specific to the engine in the vehicle the rear axle came from. This isn't always the case though, so you might get lucky. If not, you'll have to swap the drive pinion flanges(no biggie).
Dammit! You scared me there. I was gonna pitch a fit if that page really was gone all the sudden. Thank god it's not.
http://toyota.off-road.com/trucks-4x...ion-18588.html
Saving it to my computer as we speak, just in case it ever does though.
Old 01-10-2011, 05:46 PM
Good points Hippe, I dont know how I didnt catch that
Old 01-10-2011, 05:53 PM
Thanks to you All! This site is a blessing for sure. Thanks Junior
the thirds are a different width as well MudHippy? I know the entire rear axle is though. I guess by rear end I was assuming he was only looking for the third.
oh yeah and thanks, I guess the url just changed from there. Never noticed that before.
Oh and wouldn't an auto trans truck have the 4.30's and not the 4.10's? And the ones with the 31" tire option would have the 4.56's. All of these is why I had mentioned axle codes.
Old 01-10-2011, 06:59 PM
MudHippy's Avatar
Well, as far as the gears go, you just have to go by the axle code(with the exception of the pre-84 4WD PUs which all had one gear ratio ONLY depending on which year(s), details below). And hope they're still the same/haven't been swapped already. Auto or manual, 4cyl or V6/Turbo, doesn't necessarily mean that it will have any particular axle code. However, if it's an 84-88 PU or 4Runner it's going to have 4.10s or 4.30s ONLY(well..maybe...as that's all there was for those years from the factory anyway. But there were 4.38s ONLY for 79, 3.90s ONLY for 81, 4.11s ONLY for 82, and 4.10s ONLY for 80 and 83 from the factory for those years. So 4.38s, 3.90s, or 4.11s could also possibly be found swapped into any 79-95 4WD PU or 84-95 4Runner rear axle in theory). Later years(as in 89-95)may have 4.10s, 4.30s, 4.56s, or 4.88s from the factory. Just as well, 5.29s or 5.71s could also possibly be found swapped into any 79-95 PU or 84-95 4Runner rear axle too, they just didn't come from the factory with them EVER.
The 79-95 4cyl and 86-95 V6/Turbo 3rds are all interchangeable, 79-95 PU or 84-95 4Runner. The 84-95 PU/84-89 4Runner rear axle housing and axleshafts are all the same width, as is the 79-83 PU rear axle housing and axleshafts(just slightly less wide than a 84-95 PU/84-89 4Runner rear axle housing and axleshafts, by ~3.5"). The 90-95 4Runner rear axles also have the same 4cyl or V6/Turbo 3rds as the 79-95 4cyl or 86-95 V6/turbo PU rear axles, but the rear axle housing and axleshafts are ~1/2" wider than the 84-95 PU/84-89 4Runner rear axle housing and axleshafts(and the housing also has coil spring mounts instead of leaf spring perches).
zd92655
03-06-2022 12:58 PM
Weidle
01-21-2019 05:39 AM
Aleeex_u
06-05-2016 06:52 PM
Peteyg39@hotmail.com
06-26-2015 08:15 AM
bprice0077
06-25-2015 07:36 AM
Quick Reply: 1991 Toyota Pickup rearend
