what code?..
Yes it does, but it was tagged incorrectly. All you have to do is copy the url into the address bar or select it in Firefox and right-click one of the "open link in new ___" options.
In the future, put only the video's alphanumeric code, 1OZIH4Pe4Ds, between the [youtûbe][/youtube] tags or just paste the whole URL into the message body and it will open in a new window.
[youtube]1OZIH4Pe4Ds[/youtube]
http://www.youtube.com/watch?feature...&v=1OZIH4Pe4Ds
From that, I got codes 12, 13, 14, and 41 as well.
12, 13, and 14 all have to do with the distributor (NE is generated by the distributor. IGF is generated by the igniter from IGT from the ECM which is triggered by NE). So I'd look at the distributor for that group.
Code 41 is the TPS. There's a (relatively) simple diagnostic for that, and it's probably an adjustment issue (no new parts needed).
Good luck!
Where did you get all those parts? And what do they have to do with codes you're getting?
Good luck!
Good luck!
charlie_fong
09-27-2015 10:06 PM
Odin
09-26-2015 06:56 PM
