What broke?(Lots of Pics)
Old 10-15-2006, 10:12 AM
BuujinBejiita's Avatar
I was recently wheelin and heard a loud THUD. The vehicle still drove though and the 4Wheel drive works but under turns it will bind up really bad and slip. When driving down the road in 4WD it will 'Knock Knock Knock' The guys that I was with said it was probably my front diff, or a cv axle but they didnt hear the knocking, that makes me think its a driveshaft? I crawled underneath it and everythings dry except for my passenger cv boot but I think its water. The driveshaft spins fine, I found one spot if I turn it back and fourth rapidly it will kind of bang but I think a little is normal isnt it? I included some pics and I tried to describe it the best I could, any input would be greatly appreciated so I dont rip into unnecassary parts.
Thanks in advance
Old 10-15-2006, 10:26 AM
msw0085's Avatar
Looks like you have broken your CV in the bottom two pictures. That oil and twisted boot arent normal.
Old 10-15-2006, 10:37 AM
91_4x4runner's Avatar
To be sure that it's the CV, read up on this link.
https://www.yotatech.com/forums/f31/physics-cv-breakage-91633/
Old 10-15-2006, 02:59 PM
1989toy4wd's Avatar
Yeah you need a new cv joint.... that is not water, thats grease, and its okay in 2wd but I wouldnt drive it in 4wd till you get that fixed...its actually pretty bad there, so I would get it done pretty fast...!!!
Old 10-15-2006, 05:17 PM
trythis's Avatar
The thre bottom pictures look bad to me. Defintly CV joints are gonna need replacing.
Old 10-15-2006, 05:26 PM
slosurfer's Avatar
If you don't have manual hubs, the first time you hit the highway you will definately be able to tell it is grease.
Old 10-16-2006, 12:25 PM
vwfastg60's Avatar
i have the same sounds but both boots look fine and nothings leaking anyone have ideas?
Old 10-16-2006, 12:28 PM
gregbreakseverything's Avatar
Deffinatly cv joint. Your shaft is not lining up at all, its pointing the wrong direction!
oldirtydirt
02-23-2020 09:30 AM
jasonty
41
12-23-2018 01:00 PM
HookahRoo
07-20-2015 07:06 PM
lfcarrion3
07-18-2015 04:05 PM
Jnkml
07-06-2015 01:20 PM
Quick Reply: What broke?(Lots of Pics)
