starter too close to exhaust on 3vze?
Old 08-01-2005, 10:00 PM
apc
apc's Avatar
Did Toyota design the placement of the 3vze starter too close to the exhaust header? I recently changed my starter out to a Napa unit and my battery to a yellow top Optima. Yesterday was the only day this year it has gone over 30 degrees C (87 degrees F) here and the 4runner would not start. Click, click.
I bump started the rig and drove it into the garage. 5 hours later, I went out and it started as normal; did this about 10 times.
My thought is the heat from the exhaust expanded something in the starter to no make a connection.
Any thoughts?
Old 08-02-2005, 05:13 AM
Guest
94x4's Avatar
The position of the starter in relation to the exhaust manifold has never been a reported problem as far as I know.
I'd suggest checking your connections on that newly replaced starter.
Old 08-02-2005, 08:12 PM
mtnfreak's Avatar
Check your starter relay. Are you getting enough juice to the starter? I've got an automatic - no relay and had to add one because the starter wouldn't turn when it was hot out.
Old 08-04-2005, 01:01 PM
4Crawler's Avatar
It is not uncommon for new (rebuilt) starters to have problems internally. Also could be a wiring/relay/switch problem in your truck, have a look at this page for some ideas:
http://www.4crawler.com/4x4/CheapTricks/Starter.shtml
Old 08-05-2005, 05:09 AM
justanother4x4's Avatar
before blaming the starter, i would check the grounds
he's gone
7
12-03-2019 07:08 AM
Team420
12-30-2015 01:31 PM
RobotMoose
Diesel Swaps
08-02-2015 11:00 PM
clok
08-01-2015 09:42 PM
colinmil
07-06-2015 04:03 PM
Quick Reply: starter too close to exhaust on 3vze?
