Sonoran Steel IFS brace? strength
Old 02-11-2007, 03:56 PM
Adawg_08's Avatar
I read somewhere that if you get this it will help keep it alinged. Every time I wheel it needs an alingment. Is this something to get or a waste of money? Do any of you have it? Does it take very long to install? Please Help. I don't want to destroy my trucks suspension, I want it to last longer.
Aaron
http://www.sonoransteel.com/Early_IFS_Brace.html
Old 02-11-2007, 04:19 PM
Bill's Avatar
I've got one and it's great.
As far as keeping your truck in alignment: there are lots of parts to get banged up. What it will help with is keeping your rear a-arm mounts from bending in, thus keeping your steering stuff all with-in spec, or at least close enough you can adjust it back. This is true of any truss, they all do the same thing. I got the Sonoran one because it's HUGE!!!
As for how long/easy it is to instal, depends how sharp your drill bits are. They're made from 1/4" steel, and you have to drill through the a-arm mounts. With a sharp bit, can of WD-40 and a fast drill, I'd say an hour tops.
Old 02-11-2007, 04:52 PM
slosurfer's Avatar
I've got one and it is awesome! I have had the whole front end sitting on it before. It will make a great mounting spot for a skid plate soon. Ease of mounting depends on your drill bits and muscles!
Old 02-11-2007, 05:04 PM
95toybox's Avatar
Will this work with a 5" lift kit as well?
Old 02-11-2007, 05:10 PM
Fergie's Avatar
https://www.yotatech.com/forums/f31/sonoran-steel-ifs-brace-install-106216/
That is the link to the mini-write-up I did.
kawazx636
10-06-2021 03:03 PM
83yotastockR
11
11-10-2015 06:54 AM
Obmi
10-04-2015 11:30 AM
dirk89
10-01-2015 05:15 PM
hiluxinargentina
09-30-2015 05:51 PM
Quick Reply: Sonoran Steel IFS brace? strength
