replacing the factory front crossmember
Old 11-03-2010, 01:52 PM
yotarover's Avatar
i finished my bumper, only to realize it was pointless in using it with the front cross member being weak. since i can picture things better than i can cad or draw with sketch up and sw's. this drawing wont look right to some.
i plan on cutting out the cross member and replacing it with 28"x 2" C channel
cut the ends at a 45* angle, weld on the pieces to slide into the frame/weld to frame and drill 2 holes through the center of the frame and bolt with grade 12's. and 4 tabs of 1/2" thick steel plate
if im looking or thinking wrong somebody correct me
Old 11-03-2010, 02:01 PM
bobby_duce's Avatar
hmmm im kinda curious to see how this turns out, when do you plan on doing this?
Old 11-03-2010, 02:43 PM
blake.nemitz's Avatar
sounds solid post some pics when your done
Old 11-03-2010, 02:45 PM
stock as possible's Avatar
You'd rather do this than just adding a reinforcement plate?
Old 11-03-2010, 03:11 PM
yotarover's Avatar
as soon as i get a chance to hit the metal supplier. i got to idea from 4x4wire if i remember correctly, he was talking about how his was bent and warped. i'll cut the pieces first weld them together tabs and all, to keep the heat off the frame then run a few small beads to both
Old 11-03-2010, 03:14 PM
yotarob2005's Avatar
This?
http://frontrangeoffroadfab.com/nfos...9637f619d78da9
yotarover's Avatar
sure why not ? if i feel that i need super pro welder to do the welding to the frame and to make sure that the front of the frame doesn't warp the least lil bit or move outta place i'll take it to a super pro and have them do it. i even thought about using a solid piece instead of the channel
Old 11-03-2010, 03:24 PM
yotarover's Avatar
Originally Posted by yotarob2005
yeah i already looked into those and all the rest ( rather make my own) this is where i got the idea from http://www.nwtoys.com/content/123-fr...ification.html
voiddweller
19
05-02-2016 09:10 PM
PureTacoma_Tundra
PureTacoma_Tundra
06-29-2015 09:45 AM
Niameyrider
06-25-2015 05:50 AM
dirtrider0129
10
06-24-2015 12:24 PM
Quick Reply: replacing the factory front crossmember
