Removing Flywheel
Old 10-20-2009, 03:40 PM
TSintercept's Avatar
Removing Flywheel
I am swapping out the engine in my 88 4Runner manual from a 95 4Runner auto and I am trying to change the flywheels. The problem I am running into is that I cannot remove the bolts on the flywheel. Any suggestion would be great!
Old 10-20-2009, 03:59 PM
Tubbyfatty's Avatar
The bolts that hold the flywheel on to the crank?
They can be on there good. Get some PB blaster and let it soak, you do not want to break those off. If you want new ones, GO TO THE DEALER, dont go to a hardware store for them. The dealer only wants like 1.80$ for each.
Old 10-20-2009, 04:36 PM
Karlton's Avatar
Assuming your engine is out of the truck .... I used the LH (or rear) engine hanger to hold the flywheel in place. It's easy to bolt it to the block so that the hook part of the hanger engages with the flywheel teeth and holds the flywheel in place. PB Blaster and a long-handled socket wrench with a 6-point socket.
Old 10-20-2009, 05:15 PM
iamsuperbleeder's Avatar
I've found an impact to work the best, otherwise, just use a point a 6-point socket on a breaker bar, and tap the handle with a hammer in the direction to losten it. The cranks going to turn, sure, but the quick sharp "jar's" to the handle should break them loose
Old 10-20-2009, 05:24 PM
874runnersr5's Avatar
why not 12point socket?? thats what i used to get mine off
Old 10-20-2009, 06:13 PM
ok that sounds like it could work but where do I put the hanger to engage the teeth? (maybe I am just not thinking right about it)
Old 10-21-2009, 05:51 AM
Karlton's Avatar
At the time I removed mine I was feeling pretty proud of myself for coming up with a solution for holding the flywheel in place. I thought maybe I should get a photo of it to share on Yotatech, but I failed.
If my memory serves correct, I think I used one of the starter mounting holes. Mounted the hook on the transmission side (back) of the block with the hook facing the rear so that it could swivel around on the bolt and catch the flywheel teeth. Then tighten it in place.
I embarrassed to admit it, but I had forgotten to loosen the crank pulley bolt on the front of the engine before pulling it out of the truck ... and this goofy little engine hanger hook in the flywheel trick enabled me to get the pulley bolt out as well.
Good luck!
Old 10-21-2009, 05:57 AM
Karlton's Avatar
12 point is okay if that's what you have to work with. An appropriately sized 6 point typically holds better and is less likely to round-off the corners of the bolt. Especially if you are using an impact wrench, or breaker bar.
Old 10-21-2009, 08:24 AM
weird, my 12 point grabbed the bolt perfectly..
my bolts look like this..
Old 10-21-2009, 08:35 AM
Karlton's Avatar
Hah! Those are fancy bolts!
Good point ... if you've got the Super Strong Flywheel Bolts from Toyheadauto.com you'll want to use a 12 point socket.
Old 10-21-2009, 08:45 AM
haha, they looked like those not sure is they are from there or not.
i just figured that was oem? oh well news to me!
he's gone
7
12-03-2019 07:08 AM
akamon808
3.4 Swaps
12-16-2015 08:45 PM
smithyboy69
11-28-2015 04:13 PM
09-04-2015 09:27 AM
TransAmBandit
07-28-2015 11:30 PM
Quick Reply: Removing Flywheel
