Rear Third
Old 12-29-2008, 08:14 AM
Hophead's Avatar
Rear Third
My rear end is making a growing amount of noise - a constant whirring on the gas and classic gear chatter on deceleration - I suspect the pinion bearing(s). Is it possible to replace the front bearing without disassembling the third? I am weighing my options wheather to repair or replace with a junkyard third.....been quoted $250 from a local yard for a 4.56third.
advice.
Old 12-29-2008, 08:20 AM
Staff
DeathCougar's Avatar
No, you will have to remove and dismantle the third to get the bearings out.
What are the miles and condition of the used third?
Old 12-29-2008, 08:23 AM
tc
tc's Avatar
Sure it's not a u-joint?
Old 12-29-2008, 09:20 AM
Hophead's Avatar
I haven't seen the third offered-I just asked for a quote last time I was at the yard - Briefly checked u-joints - they looked OK no play. We have had 2-3' of the white stuff here recently and now it is pouring rain - not the best weather to be working outside in! I crawled under the truck yesterday and felt the play at the pinion flange (drivshaft still attached) and within the play of the gears there was what seemed to feel like a rough bearing. I have access to a 'gear man' at a freinds work (Kenworth) who wound probably set up a third for a bottle of his choice. I haven't looked at what an install kit is going to cost me locally.
I will head out in a bit and take off the driveshaft and jack up the rear end and get a real feel for whats going on.
Thanks for the replies!
Old 12-29-2008, 11:54 AM
tc
tc's Avatar
Play in the pinion flange = bad
Probably means the crush sleeve got deformed and you lost your bearing preload...
Old 12-29-2008, 03:03 PM
space-junk's Avatar
is there any way to reset the bearing preload without pulling the third??
Old 12-29-2008, 03:10 PM
swapped89's Avatar
No way. all the bearing load stuff is inside the third. If your getting diff work done i would scrap the crush sleeve and have a trail gear solid spacer installed while your at it.
Old 12-29-2008, 04:44 PM
Hophead's Avatar
So.... pulled the driveshaft, rear wheels off the ground - no play in either flanges - T-case or rear diff. Rear diff spun freely by hand, no noticeable 'bad bearing' feel. Pulled the fill plug on the rear diff and took a sample - milky gear oil - water in the diff.
So on the advice of a friend I drained the old fluid and put in a 50/50 Lucas heavy duty oil additive and fresh gear oil. Obviously this did not 'fix' anything - I am just trying to get by untill I find a replacement diff.
Now obviously the bearings are not happy (found some small metal shavings on the drain plug) When driving I still get the classic gear growl on deceleration - my thoughts are that the bearings are worn (DUH!) and the pinion is now wlking up and down the ring gear.
My question is - would I not feel this movement when I tried to move the pinion at the flange?
I am going to head down to a friends shop and check the bearing preload on the pinion.
Is there anything in the t-case that would make similar noises/ symptoms?
Started looking for a replacement third.
Old 12-29-2008, 05:20 PM
Fossilized
Staff
dropzone's Avatar
better check your trannie, TC and front diff fluid too...
this thread on ttora i believe the vendor had a limited number of used thirds
available:
http://ttora.com/forum/showthread.php?t=117978
Old 12-29-2008, 05:44 PM
Hophead's Avatar
Ya I will be checking/changing front diff, tranny, t-case tomorrow.
Thanks for the link but I think the shipping would kill me!
okamikai
04-30-2018 10:19 PM
kirkrunner
07-27-2015 07:59 PM
SMOD
07-27-2015 01:45 PM
Athansinis
07-27-2015 08:38 AM
icentropy
07-14-2015 10:23 AM
Quick Reply: Rear Third
