rear bump stops for zuk mod, don't have them!
Old Jul 5, 2015 | 08:25 PM
icentropy's Avatar
Hi all, I want to do the zuk mod but don't have the lower rear bump stops on my truck. Does anyone know what the PN is for them or where i can get them?
Thanks in advance.
Old Jul 5, 2015 | 11:48 PM
wyoming9's Avatar
Red face
Last I looked at the dealer I priced them a few years ago I think they were around $50.00 each.
Find some used ones .
Old Jul 6, 2015 | 11:01 AM
icentropy's Avatar
Thanks for the info. Good to know. My problem is I live about 3+ hours from the nearest decent parts yard (pretty rural over here) so I need to find them online somehow. I did find these on ebay http://www.ebay.com/itm/150350784590 they look the same as the pics of the ones i've seen online but they're for the front axle of the pre-86 trucks. Any chance you might know if they're the same?
Old Jul 6, 2015 | 12:29 PM
wyoming9's Avatar
Red face
They look the same from the picture .
I bought quite a few things off of Bruce over the years good guy to deal with.
Where are you from??
Old Jul 6, 2015 | 12:34 PM
icentropy's Avatar
okanogan highlands in central washington. I PMed the seller to ask if they knew if they were the same as used on the rear in 86-trucks, he replied with a "nope they're different".....bummer.
Old Jul 6, 2015 | 12:44 PM
wyoming9's Avatar
Red face
I might have a set off my parts truck
I am just not sure if they are any good
They have a tendency to dry rot and break off.
I will look.
Old Jul 6, 2015 | 01:11 PM
icentropy's Avatar
I will look.
Thanks, I'd really appreciate it. Even if the rubber is messed up I could use the metal base and attach one of the aftermarket bump stops that are available everywhere like these (http://www.ebay.com/itm/141286165207) Just need them to hold the bottom of the spring in place though.
Old Jul 9, 2015 | 03:13 PM
peabody's Avatar
Zuk mod is great but my factory pressed bumps snapped off so you are headed in the right direction. Have plates too if Wyoming can't help.
Old Jul 9, 2015 | 05:32 PM
icentropy's Avatar
Hi Peabody, Wyoming looked buy couldn't find his. Do you have the base plates for the bumpstops? If so I'll buy them from you.
Old Jul 11, 2015 | 04:08 AM
peabody's Avatar
I have an extra set from parts truck. PM with zip/address; I'll send image, etc. Will want to see what you do with them.
Old Jul 11, 2015 | 07:21 AM
icentropy's Avatar
Thanks Peabody! Much appreciated. PM sent. If the rubber is in decent shape i just plan on leaving them as is for the zuk mod. If the rubber is gone or cracked I will either buy one of those aftermarket bump stop sets and install them on the metal bracket or machine some aluminum cylinders that i can moutn straight to the brackets that have the same OD as the spring's ID. Just depends on if i have the material handy.I'll definitely post up pics either way.
Jun 1, 2021 01:51 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
colinmil
Jul 6, 2015 04:03 PM
Jnkml
Jul 6, 2015 01:20 PM
Vargntucson
Jul 4, 2015 12:15 PM
