new guy here.. bad miss when engine get's hot
Old 07-25-2006, 06:27 PM
longhorn1's Avatar
i have a 1992 v6 toyota extra cab 4x4.with 152,000 miles..i bought this truck new..i have a bad miss in the engine,as soon as the engine get's hot...i have put new plugs ..new plug wires..an new distributor cap and rottery button.and i still have the miss in the engine as soon as it get's hot..has any one on this form had this proublem..if so any help would be appreciated..if there is a part..or sensor going bad ..where is this part or sensor located at.
Old 07-25-2006, 06:38 PM
whitetaco02's Avatar
you might need to do a compression test. i talked to my mechanic today as a matter of fact and he told me if I had compression problems, then it would be missing. since you changed out all that other stuff i would give that a try.
did it start missing immediately after you changed out all the wires, plugs, and such? if so, maybe you have a wire crossed or something.
maybe somebody else will chime in with some better answers but this is all i could think of this late in the evening.
Old 07-25-2006, 06:44 PM
ChickenLover's Avatar
Let's get some more info. I'm assuming that by, 'hot' you mean normal operating temp. Or are you overheating? Have you switched to a cheaper gas recently? If I run the cheap stuff, I get a miss. Also, where is the miss in the rpm range? Or does it miss all the way through?
Old 07-26-2006, 03:04 AM
TNRabbit's Avatar
Could be many things; have you pulled the codes?
Old 07-26-2006, 05:21 AM
4runnerx3's Avatar
When it starts to miss, spray a little carb cleaner at the bottom of each injector. Mine was missing after warm up and that's how I found I had injector O ring leaking.
Old 07-26-2006, 12:46 PM
longhorn1's Avatar
new guy..bad miss when motor is hot at normal condition
thanks for the info..chickenlover and tnrabbit...4runnerx3,,an whitetacoO2..i really appriciate it..if u all find any more information on this proublem..fill free to email me at ...gbthornton@wvva.net
will let u all know if i find the proublem with the info u all gave me...again thanks a lot.
Old 07-26-2006, 06:58 PM
longhorn1's Avatar
can not spray carb cleaner on the left side to the injectors..they are under the headsor rather a bar that runs on top of the head..4runnerx3...also how do u pull the codes tnrabbit and chickenlover..it misses all the way through.
Old 07-26-2006, 07:25 PM
Guardian_Saint's Avatar
As they said, switch to 91 octane if you have'nt done so, 87 octane will ping and miss at some circumstance..., and did you screw your spark plugs all the way in?
Old 07-27-2006, 07:00 AM
longhorn1's Avatar
ok guardin saint..thanks will try 91 octane.
voiddweller
19
05-02-2016 09:10 PM
slider417
06-22-2015 10:18 AM
UKMyers
11
06-24-2002 05:41 AM
Quick Reply: new guy here.. bad miss when engine get's hot
