need power/gearing advice please!
Old 02-16-2006, 03:40 PM
Bobakazi's Avatar
The Truetrac is a LSD locker, not a lunchbox. They do not affect cornering, and they make no noise. You will never even notice that you have one (or two) until you need more traction and you can now go places you could not before. They work great in the rear and front, no matter what hubs you have. Manual hubs are much better in my opinion though.
Old 02-16-2006, 03:56 PM
tc
tc's Avatar
Originally Posted by Bobakazi
5.29s with 33"s is to much for the 5sp daily driver, but should work well with an auto. Autos have less gears than manuals, so they work better with lower gears.
The torque converter in an auto doubles the available torque at low RPM (smoothly transitioning to 1:1 at higher RPMS), so you normally can put HIGHER gears in an auto. With the Toyota trannies though, the damn overdrive is so tall that you won't be able to pull the gear, so you have to put MUCH lower gears in if you have an auto or the overdrive is worthless.
Lysmachia has 5.71 with 35's, and she still is at lower RPM in overdrive than I am in 5th with 33's and 4.56.
I agree with the above - anything less than 4.88 is too tall, 5.29 for 33's with an auto.
Old 02-16-2006, 09:48 PM
KODE's Avatar
so would 4:88 be ideal for a 5 spd daily driver with 33's?
Old 02-18-2006, 08:16 PM
KODE's Avatar
ok. i just checked the numbers on my door and matched it to the site from tc.
my truck has 4.556 gears, came stock with the 31" tire package, and has an 8" diff.
Old 02-19-2006, 09:55 AM
  #25
tc
tc's Avatar
You're good for 33's then.
ashamsuddin
17
01-13-2023 03:17 AM
Steven.m.paulk
06-07-2020 10:45 AM
hiluxinargentina
09-30-2015 11:12 PM
charlie_fong
09-27-2015 10:06 PM
taraf
09-25-2015 02:57 PM
Quick Reply: need power/gearing advice please!
