long arm Blazeland and 4 inch ifs lift combined?
I've been posting pictures of the build on my build thread at https://www.yotatech.com/forums/f199...thread-203458/
As far as the Idler Arm you can read about that at https://www.yotatech.com/forums/f31/...spacers-86026/
are your coil-over lower mounts just the factory shock mounts on the LCA's?
The shock tabs on the LCAs are the factory tabs. When someone goes for a Coil-Over Conversion or a Coil Over Assist then they need to weld on some additional tabs with the correct bolt size and width. If you buy the Blazeland Long Arm kit and the Blazeland Shock Hoop Kit I can position the tabs onto the LCA for you as a special request.
Flying91
45
04-11-2024 04:39 PM
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 01:56 AM
FS[NorAtl]: some RC stuff crawler and racer
akaphilly
07-09-2015 02:34 PM
FS[NorAtl]: 05+ tacoma leveling lift front MA
akaphilly
07-09-2015 02:18 PM
