Headers installed, need help with blocking heat
Old 04-24-2012, 05:39 AM
jvsr5v6's Avatar
Headers makes great improvement in power but floor is very warm. What can I do to block off? Thanks in advance.
Old 04-24-2012, 01:44 PM
ogjohnboy's Avatar
get some header wrap from your local parts strore and wrap it all the way from the header flange to the collector.
Old 04-24-2012, 01:55 PM
92 TOY's Avatar
depending on the warranty, you may void it if you wrap the headers. I bought some heat shield stuff from the parts store....sticky on one side, comes as a sheet about 24'' x 16'' ,cuts with scissors, and I was able to provide protection for the floor, brake lines, starter and wire harness (headers are on a 3.0).
Old 04-24-2012, 02:05 PM
Motox711's Avatar
http://www.summitracing.com/parts/THE-11002/
This is what i am doing. hopefully it works.
Old 04-24-2012, 02:56 PM
ogjohnboy's Avatar
Curious, how could wrapping headers void warranty? Your arent altering them in anyway, wrap is removable and doesnt damage the header. In fact, wrapping the header is only an improvement because its promotes proper heat flow through the header and will help prevent them from warping or rusting.
Old 04-24-2012, 03:00 PM
Outsane's Avatar
there are lots of arguments about the header wrap holding on to moisture and promoting rust
Old 04-24-2012, 03:44 PM
92 TOY's Avatar
I'd have to have you direct that question to Doug Thorley headers.
see Item #2 in the warranty http://www.google.com/url?sa=t&rct=j...BN2gi0078e7Atg
Old 04-24-2012, 10:15 PM
ogjohnboy's Avatar
hmm well seems that doug thorley must use some very low grade metal if its "degrades and deteriorates" the header. Wrapping it wont trap moistures, it actually protects the header. Thats would be the same as if they said painting the header with high temp exhaust paint will void the warranty. Wrapping the header would only be beneficial. If it was so bad, they wouldnt sell it.
But what do i know, im just a metal worker, not a header manufacturer.
Another option of what you can do, is just what 92toy said, they have material that you can stick to your floor board thats alot like dynamat that will soak up and then dissipate heat.
Old 04-25-2012, 06:05 PM
jvsr5v6's Avatar
Thanks all for the suggestions.
Old 04-25-2012, 06:27 PM
BMcEL's Avatar
If it was so good, it wouldn't void warranties.
Old 04-25-2012, 08:35 PM
Greg_Canada's Avatar
Lots of places that make downpipes for turbo cars will not warranty it whenyou wrap them, they trap in heat and crack. Ceramic coating is best, then insulation on your floor...
Old 04-26-2012, 12:07 AM
TNRabbit's Avatar
Everyone who has done headers finds it cooks everything under the hood. Part of the issue is there is about 10 times the surface area, plus the metal is extremely thin compared to stock exhaust manifold.
I don't know that anyone has completely solved this issue...
Old 04-26-2012, 06:58 PM
I got my headers sprayed with this: http://www.fireballcoatings.com/inde...id=4&Itemid=12
AND
http://www.fireballcoatings.com/inde...id=8&Itemid=19
bigjstang
08-25-2021 12:41 AM
09-04-2015 09:27 AM
tj884Rdlx
08-28-2015 12:04 PM
jjrbus
07-19-2015 02:06 PM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: Headers installed, need help with blocking heat
