Hard time finding front Mudflaps....94 P/U
Old 11-28-2012, 09:55 AM
Mingus the Red's Avatar
Hello, I have a 94 reg cab, and am having a tough time finding front aftermarket mudflaps for it. Have bought two sets,(cheap at least) that said they fit the truck and they were no where near. Can't seem to track down any stock ones in the junkyards either yet. Thanks for any advice or heads-up on something that might work!!
Have the rears, just not on right now.. ty again!
Old 11-28-2012, 10:43 AM
Stetson_md's Avatar
a peice of diamond plate aluminum works as a mud flap or you can do like my dad and cut a mud flap off a semi into two flaps with a jig saw,drill the holes and bolt it up they look good on his 87 you can get those mudflaps off a semi in plastic or rubber white or black he works for the county road and bridge so he finds them on the side of the road allthe time
Old 11-28-2012, 10:44 AM
Gamefreakgc's Avatar
Check more junkyards? There's about 5 in a 25 mile radius of where I live. Check 4Runner's too, they have a lot of interchangable parts.
Old 11-28-2012, 11:33 AM
Thanks! Both good ideas!
Old 11-28-2012, 04:35 PM
Roofmaster's Avatar
I have a set of four,stock,off my truck.Took em off the day I brought her home.You want em?Come get em theyre yours.
Old 11-28-2012, 05:58 PM
brianh699's Avatar
RH 7662139145 $30.55
LH 7662235090 $31.75
tituswilltoyota.com OEM mudflaps.
Old 11-29-2012, 04:18 AM
Thanks, but thats a bit of a drive,lol
"RH 7662139145 $30.55
tituswilltoyota.com OEM mudflaps."
Thanks for the info!
Old 11-29-2012, 04:46 AM
Pat8942's Avatar
RH Number is incorrect correct P/N is 76621-35090 and they're cheaper here
http://www.toyotapartszone.com
Old 11-29-2012, 05:12 AM
Tried their Vin# part compatibility feature, didn't match up, but then again when I looked at the table of all parts for the truck, mudgaurds weren't even on the list at all. Seems like it's the right part though, So I ordered up a pair, hopefully it's at least close enough, I'll make it work. Thanks for all the info! This forum is a wealth of great info. Have had my truck for over ten years and she still runs smooth as silk thanks to alot of stuff I've found here just by searching.
Old 11-29-2012, 05:54 AM
Pat8942's Avatar
Give me your VIN and I will look it up.
Old 12-06-2012, 12:14 PM
So those part numbers were not the ones that fit my truck. I have contacted toyota partszone with the Vin to see if they have a set that do fit. These are a full 3 inches or so off of lining up with the screws inside the fender there. And one side of the mudguard is recessed, my wheel well is flat there. This is hard to find indeed.
Old 12-06-2012, 12:28 PM
subyracer05's Avatar
what if you get those ones that you can cut to size?
Old 12-06-2012, 12:30 PM
Yeah, I believe that's the route I'm gonna have to go.
Old 12-06-2012, 12:31 PM
yeah just go to like autozone or something and grab the huges ones then just cut them to size. looks good too
6th Gear
19
12-10-2019 07:31 AM
vasinvictor
01-20-2016 12:39 PM
ZONAYODA
06-30-2015 05:36 PM
renorunnerguy
3.4 Swaps
06-28-2015 09:18 AM
David_Vestfal
06-20-2002 08:30 PM
Quick Reply: Hard time finding front Mudflaps....94 P/U
