Finally getting A Yota!
#101
It cranks over and even wants to fire but it doesn't start, the longest it pretended to run was about 1 second then just crank and crank, I'll get it though, I'm sure once I clean up the injectors and the pump, and tune her up she will be fine, Then I just need to find a cheap 22r to build so I can drive this one around
#102
Be sure to check the drivetrain fluids (trans, xfer, both diffs).
I ended up eating a transmission rebuild because I did not check that (the transmission gave out before I even got it home).
#103
I'll be checking that all out after I get this stupid gas tank out, I'm really happy it has a drain plug because it was almost full, I got a little over 16 gallons of stinky gas out of it and now my garage reaks and it's coming into the house
Does anyone know how or where to dispose of old fuel?
#105
Just found out I need to take it to Boulder, they have a hazardous material place there, I also picked up my first library card and got a chilton and a haynes for it so maybe I can get unstupid about what I'm doing
#107
Really, I'll have to check into that a little more, maybe I'm too old american car but I thought that weak spark off of the coil wire meant a bad coil, all stuff to check into, I just can't wait to get my next payment for my old car so I can buy crap
#108
FWIW, they are NOT cheap, so hit the pic and pulls and get the same one. Write down the part number and take it with you.
#109
#111
#115
I just came out of a serious issue with my ignitor and it happened to be the wire running arcoss from the ignitor over the valve cover that had broke and was grounding out to the valve cover and the truck would not run...... it was very frustrating make sure that wire is not broke or nothin.... if its been sitting so long beat on the ignitor a bit with a screw driver or hammer... not too hard.... someimtes the little electrical parts in there freeze up and stick... coils usually last a long time but they go out every so often..... fuel filter i would change for sure since its been sitting so long.... check pump with a battery to see if it works or try and start the truck with the inspeaction cover for the pump off and see if you can here it running durning cranking time.... if not then its bad prolly....
runnermedic
13
09-21-2015 05:20 PM
