Difference between the r150 and r150f 5speed.
Old 11-01-2011, 03:51 PM
85gijunk4x4's Avatar
So i was looking around for a gasket set for my leaky transfer case. The transmission i have in my truck now is the R150f in my 88 4x4 pickup, with the 3vz. Along my search i came along this website
http://www.manualtransmissionpart.co...00-TC-seal-kit
Wich supposedly has the gasket set i need for my truck. The only problem i can see here is that the gasket set is for an "r150 transfer case" now if i understand correctly the "F" indacates "four wheel drive" wich means the r150 was used in 2wd 3.0's and 3.4's while the r150f was used in 4wd 3.0's and 3.4's. So what are the differences between the two, will this gasket set work for me, and how is there such thing as a transfer case for a 2wd???
Am i getting wrong information somewhere, or am i just an idiot? hehe
Old 11-03-2011, 07:45 PM
BUMP!! for the record i'm looking to get oem gaskets from the dealer, but just happened to come along this website and let the toyota enthusiests pick at it and throw out their $0.02
Old 11-03-2011, 07:51 PM
scuba's Avatar
Never have I heard that the F indicates 4WD.
Its an R150F or R151F and either come in 2 or 4WD.
Since that site lists other ACTUAL transfer cases in that list, as well as the R100 (which I've never heard of) I'd call them and ask what that gasket kit actually goes to.
Go to TOYOTA if you need a gasket kit for your VF1A 4WD transfer case. Most likely, they'll hand you a tube of FIPG.
http://personal.utulsa.edu/~nathan-b...23assembly.pdf
Old 11-04-2011, 07:53 AM
MudHippy's Avatar
The F does indeed indicate 4WD. The difference between them is the tail housing for the 2WD(R150) or the extension housing for the transfer case on the 4WD(R150F).
R150
A 2WD transmission found in many Toyota trucks. It came with two input shaft lengths pre- 1996 and 1996 and up.
Ratios:
  • First Gear: 3.830:1
  • Second Gear: 2.062:1
  • Third Gear: 1.436:1
  • Fourth Gear: 1.00:1
  • Fifth Gear: 0.838:1
R150F
A 4WD transmission found in many Toyota trucks. [V6 3VZ-E and 5VZ-FE]
Ratios:
R151F
A 4WD transmission found in only two model years of Toyota trucks(not avilable in 4runners). [Turbo 22-RTE 1986 and 1987]
Ratios:
  • First Gear: 4.313:1
  • Second Gear: 2.330:1
  • Fifth Gear: 0.836:1
R154
This is a robust 5-speed transmission found in the MKIII Supra Turbo, Toyota Chaser Tourer V, Toyota Mark II Tourer V, Toyota Cresta Tourer V, and Toyota Soarer (turbo) up to 2001.
Ratios:
  • First Gear: 3.250:1
  • Second Gear: 1.955:1
  • Third Gear: 1.310:1
  • Fifth Gear: 0.753:1
R155
A 2WD transmission found in 2nd Generation (2005+) Toyota Tacomas.
  • First Gear: 3.95:1
  • Second Gear: 2.06:1
  • Third Gear: 1.44:1
  • Fifth Gear: 0.81:1
  • Reverse Gear: 4.22:1
R155F
A 4WD transmission found in 2nd Generation (2005+) Toyota Tacomas.
R350
A 2WD transmission found in the 100 Series Turbo Diesel Toyota Hiace Super Custom.
But yeah, for your transfer case, just use some RTV and new seals for the input/output shafts. Not too hard to find those.
Old 11-04-2011, 08:03 AM
waskillywabbit's Avatar
Toyota RED FIPG and OEM seals
Done
:wabbit2:
Daenerysdad
10-01-2015 07:33 PM
viesail
09-05-2015 04:23 AM
pplusent
09-02-2015 11:56 PM
skypilot
08-25-2015 01:09 PM
scooba
08-25-2015 09:49 AM
Quick Reply: Difference between the r150 and r150f 5speed.
