Code 71 and VAFM connection??
Check the connector housing - that is pins and the wiring harness, possible that there's a rust on one the pins or one of the wire is loose or about to break. Use a fine steel brush or a sand paper to clean the pins. For the wires, you will need to slide off the rubber boot to expose the wires.
my 2cents
my 2cents
Blamalam
03-12-2022 07:34 AM
