Bad u-joint solved the noise in the drive train
I had a noise that sounds like metals scraping. It tuned out that my rear u-joint is frozen on one way. I replaced it with a lifetime one from Autozone. I hope it works well. Anyone have experience with Autozone U-joint?
Kinda sorta. I bought one once. Tried to install it, and it didn't quite fit. I could have made it work with the right size(thicker) snap rings/c-clips. But being thoroughly annoyed at that fact(and another...see below), I removed it and tossed it in the scrap heap. Then went to NAPA and bought one that I already knew would fit. Because I'd used them a couple times prior.
I'll never buy anything but Precision u-joints from now on. OEM are better, but at $55+ each...their not exactly in my price range. I can replace them with Precision u-joints 3 times for that amount of money.
BTW, did you happen to get the greasable type? Have you realized yet that you can't fit a grease gun on the zerk fitting with the u-joint installed. That's what really sealed the deal for me. Autozone u-joints SUCK!!!! I wanna beat the guy who designed them over the head with one...REPEATEDLY. If you catch my drift...
Oh well, good thing it was super-cheap I guess.
It was 15 bucks with lifetime warranty. I guess I could've gone with the dealer. ( I know someone in the parts dept.) I also found MarlinCrawler sells the one he got from Japan for 25. I'll see how long this one last.
btw, I paid a mechanic to change it out after I took out of the truck for 25 bucks. I did marked it so it goes back the same way.
Is replacing the u joint a difficult job? I will need to do this right away
Its a Pain if you don't have a vice or torch but if you do it's cake just did it at work yesterday
Same here. I took off the drive shaft this weekend to replace the pinion seal and TC output seal and the U-joints were like new.
So.... grease your U-joints and ALL your chassis regularly and they should last the life of your truck. FYI, lifted truck = extra stress and wear on U-joints. I recommend inspecting and greasing them every other oil change, ESPECIALLY with cheap'o brands.
Jnkml
07-06-2015 01:20 PM
