A-arm and tire rub?
Old 04-17-2007, 07:15 AM
GMJK86SR5's Avatar
A-arm and tire rub?
I have ball joint spacers and 33 inch tires on my 91 4runner. I have the stock steel rims that came with the 4runner. When I installed the BJ spacers, I trimmed the A-arm lip. Now, it looks like the A-arm is rubbing against the tires. I have a nice grove cut into the inside of the front tires. Any suggestions?
Mike
Old 04-17-2007, 07:17 AM
elripster's Avatar
Mike
Wheel spacers or larger tires. What tires do you have now? I have 31X10.5's "Dominators" from Discount and they clear with quite a bit of room. I also have the stock alloy wheels.
Frank
Old 04-17-2007, 07:19 AM
norcalsvx's Avatar
33x12.50 or 33x10.50??? my 33x10.50's dont rub at all
Old 04-17-2007, 07:33 AM
Yota82's Avatar
I had that problem with a factory alloy too. I have used the Tacoma style wheels in the past and it solved it. Now I run the American Racing Outlaw II 15x7 (factory width). The offset is different and they clear just fine. When I had the wheels that rubbed, I noticed that they would only do it at the suspensions full droop. They were fine at ride height. I would try a different tire and wheel combo. Do your wheels happen to be the same ones as the truck in the pic below?
Old 04-17-2007, 07:36 AM
GMJK86SR5's Avatar
I have 33-12.50. They worked on my 86 truck. i was using the 15x8, stock, aluminum, toyota wheels. Are the stock steel wheels any different? That is what I am using on the 91 4runner?
Mike
Old 04-17-2007, 07:41 AM
GMJK86SR5's Avatar
Thanks yota82,
No, I used those alloys on my 86 pickup. I am using the stock steel toyota rims.
Old 04-17-2007, 08:11 AM
AuburnRunner's Avatar
I have the same problem w/ my stock steelies. I have a set of 4runner alloys on the way that should fix it though... You could run wheel spacers like elripster suggested if you want to keep your wheels
Old 04-17-2007, 08:47 PM
GMJK86SR5's Avatar
I looked at the Rims I have been using over the years and here is the run down. My 86 alloys are 7 inches wide. A pair of alloys I bought are 8 inches wide and the steelies are wider, maybe 8.5 to 9 inches wide.
The 33x 12.5 worked on the 86 with the 33's and bj spacers. The 33's with the steelies are rubbing at the upper a-arm. So my choices are to buy spacers for the steelies or switch the 33's to the 15x7 alloys. Any suggestions?
Mike
Old 04-18-2007, 01:42 PM
Jay351's Avatar
I would buy spacers if you like the steelies, and if you dont really care, you could just go back to the 15x7 alloys.
Old 04-20-2007, 09:09 AM
GMJK86SR5's Avatar
I do not want to put a 1 inch spacer on. I would like to know if I can put my 33's on my 15x7 alloys, and would that work with the 91 4runner? Are the A-arm setups on my 86 truck the same as the A-arms on the 91 4runner? I am a bit lost as to why the 33's are worked on the 86 and not on the 91 4runner.
I measured the back spacing on the two sets of alloys and they are 4.5. It that correct. The spacing on the steelies is 4.375, so not that different. Any way, I do not want to use spacers, and would likt info on which of the three sets of rims I have will work on the 91 runner. The 15x7 alloys or the 15X8 alloys with 33's. Thanks for any help.
Old 04-20-2007, 09:12 AM
norcalsvx's Avatar
you can mount 33's on a 15x7, i've done it a few times at the shop
Old 04-20-2007, 09:25 AM
GMJK86SR5's Avatar
Thx Norcalsrv,
Thats the info I needed. I think I will go that route. Do you think the 33's on 15x7s, would fit better(as far as a-arm rub), compared to the steelies and 33's. I think the back spacing is slightly less than the alloys, and the steelies look to be 8 to inches wide. Any know the actual size of the steelies?
thanks again Mike
BushPig
10-29-2022 06:26 AM
djpg2000
11-11-2020 04:56 AM
Jamie4runner2000
06-20-2016 09:13 AM
Scatterbrain
09-03-2015 06:46 PM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: A-arm and tire rub?
