Another speedo problem.
Hey everyone,
I tried searching but no one seems to be having a problem quite like mine. Every morning my speedo doesn't work (just stays at 0) for about the first 10 minutes or so, then jumps up to correct speed. Works fine for the rest of the day. The odometer works the entire time, not problems with it. I thought it may be the speed sensor, pulled it, it looked fine. The dealer told me that if the odometer is working, it must be the speedo itself. Sounds right to me. Any other ideas? My speedo is all electrical, and I have no tach or trip. Would a cluster w/ a tach and trip work in my truck? Thanks for your help. I have a 94 pickup with manual tranny, 4X4, 22RE.
sounds to me like the cluster's going out; or at least the speedometer in it is going
it would be a good time for an SR5 cluster upgrade
https://www.yotatech.com/forums/f116...w-pics-179106/
Hey,
thanks for all the info. Bleeder, I checked out your SR5 upgrade! That is awesome. I haven't decided if I'll go for, or just put the same cluster in again. Money is always a factor. I'll let you know how things turned out.
charlie_fong
09-27-2015 10:06 PM
