88 2wd motor selection
Old 05-05-2014, 07:50 PM
85SAF's Avatar
Hey guys, this is my first post here. Always on here looking at the cool builds and searching for information. So now I got a question of my own. I recently picked up a 88 2wd 22re, its super clean but the motor is junk. (And its an auto, not for long though) I pulled to motor with the plan to rebuild a running 22re I got in the garage from the bottom up and dropping it in. Then I got thinking I wanted more power (and I like a project) so my question is what are the easier swaps to do on a 2wd I've seen threads on a bunch of 4x4s and don't know if doing a 4.3 a v8 in a 2wd is different or impossible. Or if the rear end and everything thing else would have to be changed. If anyone has done any swaps into a 2wd or knows of threads on them. Or maybe I just didn't find them because I'm blind. If my question is stupid stupid answers excepted. Here's some pics of the rigs.
Attached Thumbnails 88 2wd motor selection-forumrunner_20140505_204942.png   88 2wd motor selection-forumrunner_20140505_205027.png
Old 05-05-2014, 07:51 PM
85SAF's Avatar
Or should I just build the 22re and daily it.. (Its going to be a daily)
Old 05-05-2014, 11:47 PM
Staff
Terrys87's Avatar
Not knowing your skill level I would suggest just doing the rebuild and daily driving it as it is. When doing a swap there is fabrication, wiring, making the other motor operate with the body. A swap on a two wheel wouldn't be any more then a four wheel. Maybe adding a body lift of some sort might be needed.
Old 05-05-2014, 11:53 PM
85SAF's Avatar
Thanks for your input. I was thinking a body lift might be needed. I have a decent skill level and a buddy who would help with the fabrication. Just building the motor and running it is probably the best bet but I'll be into it around a grand or more and will end up with around 120hp. A bit of work and money to still be pretty much stock.. Was just entertaining other options.
cars-guy
08-16-2020 06:59 AM
okamikai
04-30-2018 10:19 PM
rchavis
07-27-2015 07:41 AM
colasurdo
07-16-2015 11:32 AM
hexrain
07-12-2015 01:13 PM
Quick Reply: 88 2wd motor selection
