3vze bogging hard in overdrive
Old 07-12-2013, 07:23 AM
YotaCurly's Avatar
If anyone's that had an automatic has experienced this please tell me I have researched and can't find an answer... Ok it drives good but once it hits overdrive it starts bogging hard to the point the tons start going down and it has no power you have to floor it to make it downshift because once it hits over 3000 rpms it has all it's power back but then will loose it while in over drive and slowly start bogging again
And btw no codes ....
I'm thinking fuel filter maybe ? 123,000 miles..
Old 07-12-2013, 10:58 PM
YotaCurly's Avatar
Any idea guys ? Bump
Old 07-13-2013, 04:11 AM
Punchy's Avatar
So when you put the 33" tires on you regeared?
Should have 4.88 at least in the front and rear with auto.
Old 07-13-2013, 06:13 AM
bone collector's Avatar
when is the last time you changed the tranny fluid and filter??? just a thought
Old 07-13-2013, 08:47 PM
YotaCurly's Avatar
No it's got 4.56 gear ratio and does great dont pull a big trailer well but I get 18-20 mpg on highway and honestly not since I had the truck..... How much of a differences do y'all think this would make ?
Old 07-14-2013, 11:29 AM
Punchy's Avatar
The auto are heavy overdrive and taller gears help a lot.
Taller gears help the trans not to work as hard which keeps heat and ware down.
If you are using a A340H and 4WD, the higher RPM helps keep the tranfercase engaged.
Suggestion above are good, Check the trans filter and that the fluid is clean, Also make sure you have a good aftermarket trans cooler.
Old 07-14-2013, 03:22 PM
Inu
Inu's Avatar
Mines a factory 4.88 with the factory 31s. On that note it does not like od under 2800 rpms period, and as soon as i hit a grade, any grade itll pop out of od. Now if i had bigger tires or less gear 3rd would be more usable leaving od for flatland. Or more gear and hang onto od more.
chuckross1957
06-28-2019 10:19 PM
JHalcyonM
03-06-2019 08:37 AM
alimant100
01-20-2016 05:58 PM
clok
08-01-2015 09:42 PM
Quick Reply: 3vze bogging hard in overdrive
