1993 Pickup Suspension lift options
#42
As I said before, this has been covered and covered and covered.
You chose not to search, and further not to listen to the things I have posted.
Since you need things spoon fed to you, here are the threads I found just by typing "lift" and "toytec" into the 86-95 section
https://www.yotatech.com/forums/f116...travel-201885/
https://www.yotatech.com/forums/f116...f-drop-191330/
https://www.yotatech.com/forums/f116...y-lift-169035/
https://www.yotatech.com/forums/f116...r-pics-166258/
https://www.yotatech.com/forums/f116...-after-165663/
https://www.yotatech.com/forums/f116...t-lift-199143/
https://www.yotatech.com/forums/f116...n-lift-194108/
Again, we are much kinder than members on Pirate. If you would have posted this question over there, you likely would have been banned by now. These things have been covered hundreds of times over.
#43
https://www.yotatech.com/forums/f116...-first-201994/
This should clear everything up, aside from the links I provided.
Every suspension question from now until the end of time regarding drop bracket lifts, spacer lifts, block lifts, and the like will go in that thread.
#44
You said a lot. The info that you spewed out could have been put out in a much more agreeable manner. Why is it that when on the internet egos get so much bigger. You continue to mock this situation. I say show some follow through and put down the ban hammer or go back to "Hot Women of Yota Tech" and beg for more pics. Better yet I'm done.
#45
Agreed
And for anyone that thinks I am out of line, please feel free to read rule #15
https://www.yotatech.com/forums/f104...elines-200183/
06-01-2021 01:51 PM
Vargntucson
07-04-2015 12:15 PM
