1989 toyota 4runner
Contacts die or get defective prematurely because of the poor design of the headlight wiring that causes lots of power loss on wiring and subjects dimmer-combo-switch to high current.
Fix the contacts, then to fix the above problem and help extend life of your stalk switch contacts, use H4 conversion harness. NOTE: Commonly-available H4 conversion harness converts wiring to switched-positive and will not work with Truck-Lites LED headlights.
Just to echo RAD4Runner: Clean the contacts and order a conversion harness. I got mine from Headlight Services: http://headlightservices.com/4runner3.html. It was less than $100, plug-and-play, totally easy, everything feels quality, and my brights indicator continued to work. I had considered making my own and I purchased a cheap harness from eBay (which did not illuminate my bright indicator). I highly recommend ordering a quality harness. There are others, in addition to Headlight Services, that make these harnesses.
crazytoyota4x4
149
10-07-2020 09:47 PM
4RunnerFreak12
13
12-05-2016 11:10 AM
joekerr1@gmail.com
08-18-2016 04:57 PM
TheOriginal
08-08-2016 06:01 AM
