1989 toyota 4runner
Old 05-29-2017, 10:54 AM
Jorgestoyota's Avatar
1989 toyota 4runner
The high beams on my toyota don't work unless I pull the lever back.
Old 05-29-2017, 11:09 AM
Fossilized
Staff
dropzone's Avatar
did you push the stock forward?
Old 05-29-2017, 11:31 AM
wallytoo's Avatar
like at the grocery store, where they try to make the shelves look full? or did you mean the stalk which controls the headlights?
Old 05-31-2017, 07:22 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
the switch contacts need cleaning. mine does this. it'll be the second time needing to do it. have to pull the steering wheel to do it, so haven't, yet.
Old 05-31-2017, 10:26 PM
RAD4Runner's Avatar
Yes. THIS ^^^
Contacts die or get defective prematurely because of the poor design of the headlight wiring that causes lots of power loss on wiring and subjects dimmer-combo-switch to high current.
Fix the contacts, then to fix the above problem and help extend life of your stalk switch contacts, use H4 conversion harness. NOTE: Commonly-available H4 conversion harness converts wiring to switched-positive and will not work with Truck-Lites LED headlights.
Old 06-04-2017, 01:47 PM
Staff
Terrys87's Avatar
How to clean the contacts>>>> https://www.yotatech.com/forums/f199...l#post51724567
Old 06-05-2017, 10:19 AM
very_mechanical's Avatar
Just to echo RAD4Runner: Clean the contacts and order a conversion harness. I got mine from Headlight Services: http://headlightservices.com/4runner3.html. It was less than $100, plug-and-play, totally easy, everything feels quality, and my brights indicator continued to work. I had considered making my own and I purchased a cheap harness from eBay (which did not illuminate my bright indicator). I highly recommend ordering a quality harness. There are others, in addition to Headlight Services, that make these harnesses.
crazytoyota4x4
149
10-07-2020 09:47 PM
4RunnerFreak12
13
12-05-2016 11:10 AM
joekerr1@gmail.com
08-18-2016 04:57 PM
TheOriginal
08-08-2016 06:01 AM
Florida Runner
08-03-2016 08:17 AM
Quick Reply: 1989 toyota 4runner
