1987 4x4 Pickup Refresher
Old 07-30-2010, 05:26 AM
Olas's Avatar
So I got a pretty sweet deal on this truck less than a month ago. It's not in perfect shape but the body is pretty straight and has only minimal surface rust. It has 187,000 miles and I don't think the timing chain's ever been done (the PO was clueless).
Both plastic timing chain guides are broken. The drivers side guide seems to be completely gone.
and the passenger side guide is not in any better shape.
I bought the truck up in Steamboat Springs and drove it back to Denver in this shape. Glad it held up! The chain rattled sometimes at start up and you could get it to rattle consistently at around 2100 RPM.
Old 07-30-2010, 05:28 AM
tblake88runner's Avatar
Nice rig!! Looks like a fun project.
Old 07-30-2010, 05:31 AM
Olas's Avatar
We decided it'd be best to remove the engine in order to facilitate the process and get a few other things done while it's out. I'll be doing the headgasket, valve seals, new timing cover, oil pump, fuel filter, water pump, checking the alternator brushes, new clutch and whatever else I can do while the engine is out. If anyone has suggestions on other items I should check out, please post up!
Here's the engine, ready for removal:
On its way out:
Old 07-30-2010, 05:36 AM
Olas's Avatar
I placed an order yesterday with Ted @ Engnbldr. I bought a HD timing chain kit, and the 4 piece engine kit (water pump, oil pump, head gasket and seals, and timing cover) along with the necessary gaskets and hardware. All for ~$175 shipped to my door. I was happy to be able to order most everything that I will need from one source.
This project will take time but i'll try and keep this thread updated as much as I can.
Any tips, advice and suggestions are welcome!
Old 07-30-2010, 05:37 AM
Olas's Avatar
Thanks! I'm pretty stoked on it, can't wait to have it running again.
waskillywabbit's Avatar
Looks like a nice find.
Old 07-30-2010, 06:01 AM
pruney81's Avatar
I saw that on Craigslist Denver I think and the guy was only asking $1500, what'd you get it for?
Old 07-30-2010, 06:29 AM
Olas's Avatar
Let's see..
Since I bought it i've gotten it registered and plated, new used tires on it (with great tread), P/S pump (used), exhaust manifold (used), and the timing chain kit, oil pump, timing cover, head gasket kit, water pump and i've still got less than $1500 into it not counting the time i've put in doing the work.
Old 07-30-2010, 06:36 AM
americanmcss's Avatar
Well sir, You are money ahead in that truck by a long shot. If your taking the head off you could always port the intake and exhaust runners in the head and manifolds for some better flow. I hear that a good header is the way to go with these motors too. Would like to do one myself but the $$ isnt there yet.
bigjstang
08-25-2021 12:41 AM
mskalmus
05-28-2017 07:51 AM
MTLroadierunner
07-15-2015 12:58 PM
Nickdigg
07-07-2015 06:04 AM
zd92655
07-05-2015 04:25 PM
Quick Reply: 1987 4x4 Pickup Refresher
