1987 4-runner battery discharging
Old 06-30-2007, 07:19 PM
jimtanner's Avatar
My sons 4-runner battery is discharging after a day or two. It does this with 3 different batteries,and has a new starter.It is not road ready yet but I used 3 different fully charged batteries. None of the interior or exterior lights stay on when it is turned off. I can disconnect the battery cable and it holds the charge for a week or more. That is as long as I left the cable off. PLEASE HELP......My son wants to put it on the road
Old 06-30-2007, 07:49 PM
curtiswyant's Avatar
Check for a short, the multimeter is your friend. Or pull fuses until it stops, then you'll at least isolate the circuit causing problems. Good luck.
Old 06-30-2007, 09:11 PM
isaac338's Avatar
hook up your ammeter between the negative battery terminal and ground, then start pulling fuses to find out where the short is. might be your alternator?
Old 07-01-2007, 05:24 AM
waskillywabbit's Avatar
Here is a thread that will help Jim:
https://www.yotatech.com/forums/f131...edtops-118347/
Does he have any stereo equipment like a big amp installed? Those things have to be grounded properly or they suck the life out of the battery quick.
Old 07-01-2007, 05:39 AM
jimtanner's Avatar
Hi this is jim that got the tail gate from you a while back. Right now there is no stereo at all. It's been a long project but it's almost ready for the road.
Old 07-01-2007, 05:41 AM
Check that link I gave you and look at 4crawler's suggestion...that should locate your battery drainer for sure.
I look forward to seeing that thing on the road.
Old 07-01-2007, 05:42 AM
jimtanner's Avatar
OH hows the crawler doing? Did you get the kids each a 4-runner ? Call me when you get a chance, I'm in your area sometimes and want to see the crawler. Did you tell me there is a rear disc brake conversion for his 4-runner without having to get a kit? JIM 205-541-1126
Old 07-01-2007, 05:47 AM
It's going, just got a few more things to do to it - like an exo cage.
Not yet. I got a few more years for that!
buckz6319
08-05-2017 03:50 AM
bradahman
10-01-2015 09:24 AM
JPV
09-28-2015 03:15 PM
Rcbc92
09-26-2015 03:00 PM
toyotasaurus
09-24-2015 03:30 PM
Quick Reply: 1987 4-runner battery discharging
