"Popping" noise when turning.
Old 12-05-2012, 11:12 PM
treyota's Avatar
I had a popping noise and feel when making turns, thought it was the king pin bearings. Got a knuckle service kit, did the work, still have the pop! Everything was done to spec, but I do have a 3" lift and 33"s. I know when you modify you change geometry, Anyone had the same problem?
Old 12-05-2012, 11:13 PM
treyota's Avatar
Coming from the passenger side. By the way.
Old 12-06-2012, 12:14 AM
combatcarl's Avatar
Maybe tires rubbing. Or some kind of steering stop issue. Not 100% on solid axles...tires got chew marks in them? Like getting into your sheet metal?
Old 12-06-2012, 02:56 AM
Fossilized
Staff
dropzone's Avatar
when you serviced the knuckles how did the Birfield look? did the service by the FSM?
Old 12-06-2012, 03:00 AM
treyota's Avatar
No, its a pop like when you pop your knuckles but a light pop, but unlike us its metal on metal.
Old 12-06-2012, 03:05 AM
treyota's Avatar
Birf looked good! I looked at everything, I wanted to be in there one time in ten years, thats it. Hate front ends. Did the brake pads; didn't even need it..
Old 12-06-2012, 03:23 AM
treyota's Avatar
When I turn the wheel, about 20 deg. either way it pops. Like a bad bearing. But its not, just replaced them.
Old 12-06-2012, 06:49 AM
westjohns yota's Avatar
steering box going out?
Old 12-06-2012, 11:25 AM
treyota's Avatar
I don't think so; I can feel it in my feet when I turn. And it only happens when there's weight on the front. When I have it up on stands and turn the steering wheel, it doesn't do it.
Old 12-06-2012, 03:13 PM
rokblok's Avatar
I know my pop is the spring shackles twisting and torquing. So I will eventually replace front leaf/shackle bushings. Btw, mine seems to do it exactly as yours does. Mine will also do it just sitting still in a parking lot and moving the wheel back and forth.
Old 12-07-2012, 08:42 AM
treyota's Avatar
Good call, I'll check it out!
Old 12-23-2012, 09:13 PM
84SR5's Avatar
Check your leaf spring and shackle bushings, and check your u-bolts!
zytra
01-24-2019 03:16 PM
Davebarbier
11-03-2015 03:28 PM
zombie_barbarossa
10-02-2015 10:54 PM
JPV
09-28-2015 03:15 PM
Quick Reply: "Popping" noise when turning.
