no oil in the oil filter
there is no oil in the oil filter and it only has 2 quarts of oil in the motor.would low amounts of oil cause no oil to get to the filter.
it was stolen a week later and i just got it put back together after they canabalized it.(front and rear seats,both bumpers,alternater,distributor,slashed 33 inch boggers,smashed windshield and passenger side window,rear tail lights,grill,...etc.)they had a ball.i just changed the oil today to be on top of things.thats when i realized the filter was empty and there were only two quarts.sorry for lack of info.
When you change your oil, you're supposed to do it on a hot engine, for maximum drainage. Hot oil drains faster and more thorougly than cold oil.
I use genuine Toyota filters, as they cost the same as everything else out there.
Losing up to a quart per 1000 miles is considered acceptable. 1L/1000km (1q/600mi) is considered borderline.
They're 3/4" longer than the v6 ones, so you get more filter media for the same price.
Around our shop, we stock the longer 4 cylinder ones (for corollas) and the v8 ones which fit all v6 and v8, as well as 22R.
fram.............
Please if you like your vehicles do not use fram.... complete garbage..... the "spring" they use for there bypass is a stamped peice of sheetmetal Much like a canner lid, as soon as its been popped a couple of times its done. and well no more oil is being filtered just bypassed......
fleetguard, john deere, amsoil, oem toyota, etc...... WORTH THE EXTRA $1.00
jasonty
41
12-23-2018 01:00 PM
