no oil in the oil filter
Old Feb 27, 2008 | 06:05 PM
sloppy85toy's Avatar
there is no oil in the oil filter and it only has 2 quarts of oil in the motor.would low amounts of oil cause no oil to get to the filter.
Old Feb 27, 2008 | 06:11 PM
85toy's Avatar
put in 2 more quarts and you should be fine.
ozziesironmanoffroad's Avatar
uh... why are you running it with only 2 qts in the motor? the 22re needs no more and no less than 4.5qts
Old Feb 27, 2008 | 06:18 PM
i took it to lube stop and had the oil changed a few months ago
Old Feb 27, 2008 | 06:20 PM
oh god, id start doin it yourself, those places suck!
Old Feb 27, 2008 | 06:23 PM
it was stolen a week later and i just got it put back together after they canabalized it.(front and rear seats,both bumpers,alternater,distributor,slashed 33 inch boggers,smashed windshield and passenger side window,rear tail lights,grill,...etc.)they had a ball.i just changed the oil today to be on top of things.thats when i realized the filter was empty and there were only two quarts.sorry for lack of info.
Old Feb 27, 2008 | 06:24 PM
DeathCougar's Avatar
A few months and you only burned a quart or two? Perfectly normal. Every engine burns oil, in some amount or another.
Check your oil every month, and you will be fine.
Old Feb 27, 2008 | 06:32 PM
86tuning's Avatar
Crappy filters will drain empty if they sit for a while. Was your old filter orange?
When you change your oil, you're supposed to do it on a hot engine, for maximum drainage. Hot oil drains faster and more thorougly than cold oil.
I use genuine Toyota filters, as they cost the same as everything else out there.
Losing up to a quart per 1000 miles is considered acceptable. 1L/1000km (1q/600mi) is considered borderline.
my motor is brand new.it has 3615 miles on it.read above.my oil filter was completly dry not a drop.
Old Feb 27, 2008 | 06:34 PM
so if it sits for a while the filter will drain back into the pan.
Old Feb 27, 2008 | 07:11 PM
i hope that it drained back in.and that they didnt go radin it around with such little oil.
Old Feb 27, 2008 | 07:21 PM
If it sits for a day or two even, it will drain back. Unless you have a factory filter? Please tell me you do for your NEW engine.
Old Feb 27, 2008 | 07:31 PM
no i bought a fram filter should i get a factory one.do i need to go to toyota for it or can i oredr it at napa or kragen.
Old Feb 27, 2008 | 08:14 PM
86tuning's Avatar
Filter from the dealership is like $6. And the v8 spin-on filters fit fine, for the same price.
Old Feb 27, 2008 | 10:37 PM
r the v8 spin on filters better
Old Feb 28, 2008 | 10:21 PM
86tuning's Avatar
They're 3/4" longer than the v6 ones, so you get more filter media for the same price.
Around our shop, we stock the longer 4 cylinder ones (for corollas) and the v8 ones which fit all v6 and v8, as well as 22R.
Old Mar 19, 2008 | 09:25 PM
partsguytoyota's Avatar
fram.............
Please if you like your vehicles do not use fram.... complete garbage..... the "spring" they use for there bypass is a stamped peice of sheetmetal Much like a canner lid, as soon as its been popped a couple of times its done. and well no more oil is being filtered just bypassed......
fleetguard, john deere, amsoil, oem toyota, etc...... WORTH THE EXTRA $1.00
Eggslinger
Jun 8, 2019 03:32 PM
jasonty
41
Dec 23, 2018 01:00 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
ryerye13
Jul 14, 2015 08:27 AM
