Best bolt on lift kit???
So i have an 85 runner and want to start moving forward with my plans. I know that the trail gear and allpro kits are the best but i don;t have access or ability to weld. Also i cant pay a shop to install it. I want to run 33's at least. The truck is going to see 70% on road and 30 % offroad. Not looking to do any rock gardens or insane stuff just want to hit some trails with my son when he is old enough. I am looking for some input guys. I have a feeling that 4 inches is where i will need to be but let me now if i am off base.
Rears up front, and stock leaves out back with a lift block?
I know i'll get flamed for that.
The best lift is 63" chevies in the rear, with rears up front. Usually the cheapest.
You can have a welding shop weld the perches on before you take off the old leafs, too, then go home and finish the job
The OME springs are pretty decent for 33s. Buddy of mine did those on his '83 with a body lift (already had the body lift) and it worked well. Or check the various off the shelf 4" spring vendors, I think the Superlift soft ride are supposed to be fairly decent. Look for a kit with springs all around (no rear blocks) and the shocks and other parts you'll need.
i also made the front shock hanger higher for longer shocks and moved the rear ones off the ublots to the axel and tilted in twords the center of the bed. other then that all bolt on
If you have the money and the time, have custom Alcan Springs made. While a bit more than the off the self units, they are worth EVERY penny. You will love them and they will not let you down. Add in greasable Old Man Emu shackles and your set besides for shocks. =-)
I have a 4"-ish lift on my '84 pickup. I was told it was a Rancho. Front springs, rear blocks. Its a bit stiff, but not a total kidney killer. I drive it sometimes 300+ miles a day and it doesnt make me hate it. It just feels like a 4wd truck to me.... I've ridden in Cruisers and Ford Hi-boys and Chevy 4wds that were ALOT stiffer than mine... Only thing I would change, on a budget, would be shocks. I've got some off-brand on there now, but I am changing to the Bilsteins soon.
And a definite recommendation, get the Trailgear Hysteer. The factory push/pull setup on a 4" lifted truck is just dangerous.... Its a bit of a budget stretcher, but MUCH SAFER..... And the components(tie rods, tie rod ends) are super beefy. Its a must for a lifted, factory solid axle, in my opinion...
if your looking a for a cheap lift pro comp makes front lift springs 3to 5 inches. 50 bucks each for the front and i think 100 each for the rear. i would get 3 inch front lift springs and do blocks in the rear. i havr the 4 inch pro comp and my steering is terrible but i cant afford a hysteer right now
thanks guys i think i am leaning tword the procomp kit and doing a trail gear high steer kit. i will see how it does and then regear it as nessisary
I just installed a procomp lift 3 days ago and I have to say I am pretty impressed !! I went from the stock springs with some extended shackles to a 3" procomp kit including shocks and kept the extended shackles and its night and day the ride is better and they flex pretty darn good . I even tried to flex it enough to see if im going to have a drive line issue and everything seems just perfect . Im so excited now i cant wait to get the motor rebuilt and the gears and locker !! I dont rock crawl but i do climb around on the pretty awesome drt trails and im suoer excited to get it finished now . the lift was just the kick in the pants i needed !!
Yeah that is a sick ride 6th gear . Makes we want to ask Santa for a 4inch lift with high steer !!
____________
85 sr5 33x12x50 new moog tie rod ends and bearings in front . leveled in the back
____________
nice thing abut the procomp kit too is you get brake lines, sway bar extenstions, steering correction pieces, all the little knick-knack parts you seem to always end up rushing all over town for on sunday afternoon, lol
Yeah that all sounds nice and good ,now . before people on here were like did you see that feed ,blog go look at it etc... and any way this sounds like the one I would like for $600.00 but already been sinking Quid into this beast . So for now this sounds like good info and put it on the list . Just put new tierods on and its still the wondering prob. cuz that push pull steering and other ball joints ? FINALLY JUST PUT HER IN 4 WHEEL. It was nice went to the dunes and went on some cool stuff, saw a totaly killer caged locked 4runner also . it was BADD!
Flying91
45
04-11-2024 04:39 PM
09-04-2015 09:27 AM
coffey50
07-28-2015 10:55 AM
justdifferentials
Just Differentials
07-22-2015 08:26 PM
whereAreMyPants
07-22-2015 03:32 AM
