89 runner 22re with oil leak cannot locate
Old 11-05-2012, 05:40 PM
89_Runner's Avatar
So here's some history. Blowen motor when purchased. So i ripped it out and put in a motor i had in the garage. It was a block loaded (crank, pistons ext.) Put on a newer head. New gaskets for everything. Get it back in the truck. Got it running. Now when its just sitting there running or with me hitting the throttle under the hood no leaks. But when i go on test drives it starts leaking like no other. It only leaks on the foward left hand side of the block. It seems to be around were the water tube connects to the front cover. But i know thats were coolant is. I have put on another front cover and its leaking from the same place and only when driving no ideling. Any ideas struggling here. Thanks
NEED HELP JUST CANT FIGURE IT OUT. ANY IDEAS ILL TRY ANYTHING. THANKS
Old 11-05-2012, 07:18 PM
89_Runner's Avatar
im guessing this hasnt happened to anyone before? any help please
Old 11-05-2012, 08:48 PM
BigBluePile's Avatar
Does the leak happen in your garage running @3k rpm? Oil pressure at idle is way different than that at operating rpms
Old 11-05-2012, 09:02 PM
89_Runner's Avatar
when i hold the throttle open its ok. But when i start driving down the road its leaking. On second timing cover cause i thought i had a bad one but still leaking from same spot. And on this second cover i used gasket and rtv silcone but no help.
Old 11-05-2012, 09:05 PM
7m4x4dude's Avatar
Install the small bolt into the very front of the cover? Goes through head into center of cover.
Old 11-05-2012, 09:19 PM
89_Runner's Avatar
the bolt that goes under the gear for the distributor. i have that one installed.
Old 11-05-2012, 09:47 PM
89_Runner's Avatar
it seems to be under the p/s bracket like right under it. not sure what is back there
duckhead
170
11-13-2017 06:07 AM
JF9243176
10-08-2017 04:21 AM
voiddweller
19
05-02-2016 09:10 PM
JF9243176
06-24-2015 04:53 AM
bobbybouche
06-18-2015 10:22 AM
Quick Reply: 89 runner 22re with oil leak cannot locate
