1985 Toyota Pickup high idle and stumbles
Working on my 1985 toyota pickup, it was swapped to the 22re by previous owner. It seems to warm up at about 1400ish rpm and slow raises from there to 1900ish. Also during this time, it has stumbles regularily while idling. Just looking for advice on what it could be, and things to check into.
The guy I bought the truck from said the truck has a walbro 255 in it, and I come from the import car world and you really cant just put that size fuel pump in with out a afpr to control it. Could that be part of the issue?
Thank you
Doug
Thank you
Doug
I am sure the truck has a fpr but I know on cars I have dealt with before if you do not have an adjustable fuel pressure regulator the car will run rough as the larger fuel pump is over flowing the stock fpr.
- http://www.4crawler.com/4x4/CheapTri...ine_Pix/8.html
- http://www.4crawler.com/4x4/CheapTri...ine_Pix/9.html
- http://www.4crawler.com/4x4/CheapTri...ne_Pix/10.html
If not, pressure is too high at idle and it won't run right.
6th Gear
19
12-10-2019 07:31 AM
Peteyg39@hotmail.com
06-26-2015 08:15 AM
Eagle564
06-23-2015 11:29 PM
JaredL
06-16-2015 04:47 PM
