Quick "what's it worth" Question...
EDIT: MOTOR ONLY
1982 22r
~10K miles
.040 over
ARB main and head studs
LC Engineering street performer head/cam...30k on cam. Valve job and resurface when rebuilt 10k ago.
LC Eng. Adj Timing gear
Offy C intake
Weber 32/36
NWOR header
Motor has been sitting for about a year, but still fires right up and runs good. I need to sell it to fund a 4.3l swap and am just trying to figure out what it might be worth. Thanks in advance for any opinions.
1982 22r
~10K miles
.040 over
Offy C intake
Weber 32/36
NWOR header
use bluebook then add a few hundred more for everything. are you saying it has only little over 10,000.?
why are you selling it? if you still got many more miles to go, dont get robbed out and sell it.
Sorry, I wasn't very clear. This is the motor only. I need to get rid of this motor/trans to make way for a 4.3l swap into this truck.....someday
What parts did you buy new?
Pistons, rings, bearings, crank turned, oil pump, water pump, head and main studs, adjustable cam gear, timing set, valve guide seals, head resurfaced and valves turned, cam has about 30K on it
Do you have receipts for parts and machine work?
yes, have all receipts
.60 over is a little scary IMO for a daily driver
I'm glad you brought that up, I checked and if fact it's only .040 over
Who built the motor?
Me.
Me.
kawazx636
10-06-2021 03:03 PM
zytra
01-24-2019 03:16 PM
charlie_fong
09-27-2015 10:06 PM
