Quick "what's it worth" Question...
EDIT: MOTOR ONLY
1982 22r ~10K miles .040 over ARB main and head studs LC Engineering street performer head/cam...30k on cam. Valve job and resurface when rebuilt 10k ago. LC Eng. Adj Timing gear Offy C intake Weber 32/36 NWOR header Motor has been sitting for about a year, but still fires right up and runs good. I need to sell it to fund a 4.3l swap and am just trying to figure out what it might be worth. Thanks in advance for any opinions. |
use bluebook then add a few hundred more for everything. are you saying it has only little over 10,000.?
why are you selling it? if you still got many more miles to go, dont get robbed out and sell it. |
Originally Posted by infiltrator
(Post 50660805)
Need more info:
What parts did you buy new? Do you have receipts for parts and machine work? .60 over is a little scary IMO for a daily driver Who built the motor? |
Pistons, rings, bearings, crank turned, oil pump, water pump, head and main studs, adjustable cam gear, timing set, valve guide seals, head resurfaced and valves turned, cam has about 30K on it Do you have receipts for parts and machine work? yes, have all receipts .60 over is a little scary IMO for a daily driver I'm glad you brought that up, I checked and if fact it's only .040 over Who built the motor? Me. |
If it was turn key I would say $1300 OBO is what i would ask.
Originally Posted by paxil4x4
(Post 50660925)
Where is this engine?
Pictures? |
What about a warranty? I wouldn't pay more than $800 or so on an engine that has no guarantee.
Originally Posted by 85TurboRunner
(Post 50661505)
(Post 50661505)
