Homemade Slider Build-up
After a couple months of research, too much money in tools, and a sudden jolt of motivation, I finally launched on this project today.
It all started with this...
Tools used:
120V Wirefeed welder with flux core wire
Harbor Freight Cutoff Saw
Angle Gringer
Wire Wheel, and Brushes
Welding Table and Vise
Protractor
Designed on Solidworks.
A dozen measurements from the truck scribbled on the back of an envelope, and a couple of hours playing on solid works netted this.
Solidworks is an amazing program. Pricey, even for the personal version, but HIGHLY recommended.
A few hours in the shop, and plenty of time fixing my crummy chop saw job with the grinder and I had one side almost complete.
This is my first metal fabrication job. I just learned how to weld a couple weeks ago, and I'm actually plesantly suprised at how well it's coming along. I've had to grind out and fix a couple of welds, and I screwed my angles ALL up with the chop saw, but nothing the angle grinder couldn't fix. After it was welded up, I was within an 1/8th of an inch of the plans between the outside points.
I'll tell you what, this is MUCH more work than I thought it would be. I've got a new level of respect for all the folks who do fabrication for a living. But that said, it's an absolute blast! I'm learning tons, and there's a couple of guys in the shop where I'm working that have some moderate interest in what I'm doing. Every once in a while they wander in and show me how I'm screwing something up.
Updates will follow. I'll be back in there working on it Saturday. Any suggestions are appreciated, and any questions I'll do my best to answer.
Tools used:
Angle Gringer
Protractor
Gorilla cut w/ the chop saw and always square the "blade" with the holding piece...or you'll get a bad angle every time. Don't go by the angle finder on the saw...mine is NEVER on target and a couple degrees makes for an ugly cut and time w/ the grinder.
Looking good.
Looking good.
Originally Posted by Ric
looking pretty darn good for just learning to weld.. are you going to cap the ends ?
One of the guys at the shop gave me the scoop on how to cap them, so we'll see if I can make it look decent.
heres a suggestion you dont want to hear -
take back the HF chop saw and get a better one (basically any of the models at Home Depot/Lowes are better...). me and chris (getitdone) tried using his HF chop saw to make his sliders, and it sucks. it doesnt cut straight down, and everything had to be ground square.
other than that, they look good. is that 2x2 1/8"?
keep it up...
keep it up...
keep it up...
keep it up...
Good call on the HF saw though. It gets the job done, but you do get what you pay for, and I never did like spending an hour slinging the angle grinder.
Yep, 2x2 square. .125 wall (11 gauge I think). Heavy...
I wouldn't suggest doing it, if you plan to use the sliders. probably heard it a bagillion times, but I would make diamond shaped scab plates. Cut them square and turn them so the corners are pointed North, south, east, and west. This will distribute the strain better. You wont be pushing on a vertical, or horizontal weld. For even more strength you could even drill a couple of holes towards the center of the plate, and weld there also. Looks really good for a beginner, and I hate to say it that way, because I would have believed you were experienced from looking at the pics.
As an update, I've got both sliders completely welded up and painted. They're probably going to be welded on the truck tomorrow.
Hey, this may be a stupid question but, when you guys say 2" square tubing or 1 3/4" round tubing, is that measured inside or outside??? The reason I ask is the maintenance shop at where I work has a large supply of 1 1/2" (ID) 80 schedule pipe that I was wondering if it will be enough for fabbing up sliders with. Any ideas?
Tubing is called out as outside diameter x thickness
Piping is called out as NOMINAL diameter x schedule (wall thickness)
The two have different names for a reason as they are different.
Generally, piping is for pressure retention, tubing is structural.
1.5" SCH 80 Pipe is 1.5" ID (just happens to work out that way) or 1.90" OD.
Sure you can use it for sliders, personally I would not.
Google pipe vs. tubing and do some light reading and you'll learn a lot.
Sliders Finished
After a LOOOONG delay, here's the completed pics of the sliders. The project took longer than I thought it would, but the end results were totally acceptable. For my first fab job, I'm pretty satisfied.
These are set to a 15degree angle to horizontal, and so far that has worked pretty well for me.
My measurements were all spot on, and required no adjustments in mounting. Anyone that wants to copy the design, feel free to use the measurement sheet posted earlier in this thread as a guide.
Any thoughts, or suggestions on this project are welcome and appreciated!
