Wireless router - limited or no connectivity - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Electronics > Computer Talk
Welcome to Yotatech!
Welcome to Yotatech,
Old 02-16-2006, 07:39 AM   #1 (permalink)
HaveBlue's Avatar
Send a message via AIM to HaveBlue
Hey, all!
I bought a Llinksys Wireless-G (WRT54G) router a couple weeks ago. All was working fine until last night. I could not connect to the internet. I connected the cable modem to my laptop, that's not the problem. I reset the router and went through setup again. Now I can connect, but I have "limited or no connectivity" and can't connect to the internet wirelessly. WinXP shows the router on available networks. And it asks for the WEP Key when I double-click on it. And it connects. But after it connects, I get "limited or no connectivity."
Can anyone help me, please?
Thanks!
__________________
Alan
1996 Supercharged 4Runner Limited
Hi Altitude 4Lo A 4WD club for Colorado and surrounding states
HaveBlue is offline
Old 02-16-2006, 10:08 AM   #2 (permalink)
Jeffires's Avatar
Send a message via AIM to Jeffires
I have the same equipment: You are not getting DHCP to get the IP address to connect to the Internet. Did you go into the configuration of the router through the web browser set up utility? If so, you may have changed something that affects the number of DHCP addresses given out. Also, do you live in apartments, or areas where there may be a high number of 802.11 signals being broadcast? Be sure you are connecting to your router. Set up a unique SSID (name) for your network. When the wireless quits working- hook up your laptop to a port on the back of the router, and see if you can use it that way. If the wireless quits, but you can still connect through a Cat5 plugged into a port on it, I am almost certain it is a configuration issue with the NIC or the Router.
__________________
-Jeff-
'91 4WD P/U 3VZE A340H , 197K
K&N air ] Optima ] Flex-a-Lite fan ] FloPro exhaust ] ISR Mod ] Warn M8000 ] Powertrax lockers ] Swaybar Discos ] KC Lighting ] Premier MP3 - Pioneer highs/mids - RF DVC 12/ RF 360a² ] Garmin GPSMap60C
Photo Album
MySpace
La Nouvelle-Orléans
'da Ragin Cajun
Jeffires is offline
Old 02-16-2006, 10:29 AM   #3 (permalink)
rwmorrisonjr's Avatar
Location: Home: Aurora, CO; Work: The People's Republic of Denver
Alan, what he said. If you want, I can come by and look at it since I have alot of free time these days!
__________________
DD: 2006 Jeep Commander Sport 4.7l
Trail rig: 1984 BII, 2.8, MSD 6A & Blaster 2 coil, Holley 2300, C5, OEM 1350, 7.5 & D28 with 4.56s, 33x12.50 BFG AT KOs on 15x8 black steelies, new "jeep" seats. Ugly but it runs and its paid for!
"An armed society is a polite society. Manners are good when one may have to back up his acts with his life."- Robert A. Heinlein
rwmorrisonjr is offline
Old 02-16-2006, 11:48 AM   #4 (permalink)
arjan's Avatar
When troubleshooting it is often easier to turn wep & wpa off, one less thing which can bugger things up. That's just been my experience. Once you can connect without encryption, then turn it back on and see if your passwords (keys) are a problem.
__________________
2006 4Runner V8 Sports Edition
Red 1997 4Runner 3.4L Bushwacker Flares, 5spd, E locker
arjan is offline
Old 02-16-2006, 12:02 PM   #5 (permalink)
Buck01's Avatar
do you have any software firewall type stuff?
__________________
94 Toyota Truck 4x4 22RE, 5 Speed 175,000
MOD's include High performance Head with bigger valves and cam, LC engineering Header and complete exhaust kit.
I have upgraded headlights with the wiring harrness and Hella H4 allweather bulbs.
lift shackels in the rear
3 inch BL
Buck01 is offline
Old 02-16-2006, 12:18 PM   #6 (permalink)
Churnd's Avatar
Send a message via AIM to Churnd
It sounds like your router or wireless card is still configured with some kind of WEP or WPA key. How did you reset the router? There's a "soft" and a "hard" reset. The soft reset just reboots the router, while still retaining the settings you configured. The hard reset wipes those settings out and restores it to how it was when you first bought it (assuming you bought it new).
So, assuming you don't mind losing your settings once more:
  • Do a hard reset and make sure WEP/WPA is turned off on your wireless card. If that doesn't work...
  • Update the firmware on your router. If that doesn't work...
  • Reinstall the drivers on your wireless card (or just reinstall the wireless card altogether). That shouldn't have anything to do with it, but it would certainly eliminate a problem with the card.
Normally, I'd say update the firmware first, but it sounds like you may have botched up settings on the router. So I suggested resetting it first to eliminate that possibility.
Click here to get your firmware
__________________
-Chris
If you can't explain it simply, you don't understand it well enough.
Click here to search!
My Website
Churnd is offline
Old 02-16-2006, 02:42 PM   #7 (permalink)
CynicX's Avatar
Send a message via AIM to CynicX
I recommend doing a hard reset. My linksys router does this from time to time but its around 3 years old. I just cycle the power and its fine.
If the hard reset works then update the firmware. Use an ethernet cable when doing so, although I've done it wirelessly I believe Linksys recommends being connected to the router...
__________________
06 Subaru WRX
CynicX is offline
Old 02-17-2006, 10:53 AM   #8 (permalink)
Alan, did you have time to work on this last night?
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
wireless router troubles doink Computer Talk 10 01-01-2007 03:44 PM
What kind of Wireless router? Yamaha+Toyota=Fun Computer Talk 9 06-22-2005 09:37 PM
Wireless router/networking questions Bob_98SR5 Off Topic Talk 33 03-25-2004 03:07 PM
An alternative to a wireless router JSB Off Topic Talk 23 11-12-2003 11:59 AM
2009 InternetBrands, Inc.
