Problem upgrading Windows XP from SP1 to SP2 - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Electronics > Computer Talk
Welcome to Yotatech!
Welcome to Yotatech,
Old 02-21-2006, 09:14 AM   #1 (permalink)
Cebby's Avatar
Send a message via AIM to Cebby
I've been trying this for some time now. I've been deleting various applications hoping to stumble upon the one that has a stranglehold of the system.
I'm using Windows Update. It has installed all the hot fixes and little security things that needed to be installed, but when it comes to SP2, it fails the install.
When it gets to roughly 40%, I get an error that says "Access denied" and then I have to let the install revert back to the previous install/files.
Trend Micro anti-virus has been removed as well as a few other items that were sitting in the systray. I've tried to install my Comcast modem and get errors I thought there might be something related.
__________________
UZswap.com
A site dedicated to sharing info for swapping the Toyota/
Lexus UZ (V8) engines into Toyota Trucks and 4Runners.
My 4Runner
1993 4Runner, 1UZ (V8) auto dual ultimate crawler, double locked, 35's on beadlocked SR5 alloys,
low lift, hacked fenders, tubbed firewall, custom armor
TOOLandFAB.com
A discussion forum dedicated to tools, fabrication & workshops. See my JD2 Bender Hydro Conversion
Cebby is offline
Old 02-21-2006, 10:29 AM   #2 (permalink)
li_runner's Avatar
Assuming the user you are logged on as has administrative rights, it sounds like there is a program blocking the installation files from properly running. Do you have any anti-spyware, or any programs looking for spam, firewall, privacy controls, or anything along these lines.
If not it, how about this. Is it possible the downloaded copy of SP2 is corrupted? Maybe another copy of the download would work?
__________________
-Pete
RIP *97' 4Runner SR5*
New baby: 07' Sport v6 Shadow Mica
li_runner is offline
Old 02-21-2006, 10:48 AM   #3 (permalink)
Churnd's Avatar
Send a message via AIM to Churnd
Quote:
Yes it is: SP2 Download
Nevermind what it says at the top about being for IT Professionals. It just downloads the setup file to your computer, then lets you run it when you want.
Look at your software that's running too. I've never had any problems with software interfering with SP2, but it's a possibility. If you're getting an error message, post the entire message here. That helps lots.
If that doesn't work, grap your XP install CD and pop it in while Windows is running. Go to Start > Run then type sfc /scannow. That checks your system files and makes sure they're in their original states. Once that's done, try running the SP2 install again.
If that doesn't work, there's other options we can consider. But I'll leave those out for now.
Of course, SP2 won't install on a computer with an illegal CD Key. If that's the case, it doesn't necessarily mean that you have an illegal key. If you're certain you don't, give MS a ring and they can sort that out for you.
__________________
-Chris
If you can't explain it simply, you don't understand it well enough.
Click here to search!
My Website
Churnd is offline
Old 02-21-2006, 10:51 AM   #4 (permalink)
Cebby's Avatar
Thank Pete. I have disabled everything that I know of. As far as I know, both my wife and I are both admins -I'm going to check that though, because that is one thing I haven't checked recently.
I just tried disabling everything in the "Startup" group through "Run...-> msconfig", but got the same error at the same point.
It takes so freakin' long it seems to get to the point where it dumps and then restore itself.
As far the file being corrupted - it's possible, but when I go to install it, it says the file is already downloaded. I don't know how to force it to DL it again.
__________________
UZswap.com
My 4Runner
TOOLandFAB.com
Cebby is offline
Old 02-21-2006, 10:55 AM   #5 (permalink)
Cebby's Avatar
Chris - the computer came with Win XP installed from Dell - as part of the Windows updates, it validates the Windows software (which it did).
The only error I get is the "Access Denied" popup. Then it says I must click OK for it to revert.
I'll try DL'ing the file you posted the link to.
Thanks!
__________________
UZswap.com
My 4Runner
TOOLandFAB.com
Cebby is offline
Old 02-21-2006, 11:12 AM   #6 (permalink)
Cebby's Avatar
Both users are Administrators BTW.
__________________
UZswap.com
My 4Runner
TOOLandFAB.com
Cebby is offline
Old 02-21-2006, 12:16 PM   #7 (permalink)
Cebby's Avatar
OK. I downloaded from the link. The first download said it was corrupt when I went to extract it. Second download started working, but around the same point gave me the "Access Denied" box again.
I need to see if I can find my old XP disk. Since it came pre-installed, I'm not sure I remember an actual disk.
This sucks.
__________________
UZswap.com
My 4Runner
TOOLandFAB.com
Cebby is offline
Old 02-21-2006, 12:22 PM   #8 (permalink)
Cebby's Avatar
This sucks.
If the software was preinstalled can I run the sfc /scannow from the HDD since there are likely cabinet files on the HD?
__________________
UZswap.com
My 4Runner
TOOLandFAB.com
Cebby is offline
Old 02-21-2006, 12:28 PM   #9 (permalink)
Cebby's Avatar
Not sure if this means anything, but when I was trying to install my new Comcast modem (Motorola 5101), the Comcast Software kept quitting and giving me an error that it couldn't access kernel32.dll
Think this problem is related?
__________________
UZswap.com
My 4Runner
TOOLandFAB.com
Cebby is offline
Old 02-21-2006, 12:38 PM   #10 (permalink)
Cebby's Avatar
One other nagging problem on my computer and my wifes is that every time we go into Outlook, we get a message titled MS Word that says:
"This file contains macros with an expired or revoked signature. Since you are running under High Security Level, these macros will be disabled". (with an "OK" box)
Then when exiting I get a message titled MS Visual Basic that says:
"The macros in this project are disabled. Please refer to the online help or documentation of the host application to determine how to enable macros." (with an "OK" and "Help" box)
I doubt this is having a bearing on the SP2 upgrade issues though since mine upgraded without a hitch (but still has these errors)
__________________
UZswap.com
My 4Runner
TOOLandFAB.com
Cebby is offline
Old 02-21-2006, 12:43 PM   #11 (permalink)
Churnd's Avatar
Somehow, some of your OS files have been corrupted. There should be a disc from Dell that came with the computer labeled "For reinstalling the OS" or something like that. Put that in, then run sfc /scannow. It won't (as far as I know) run otherwise.
If that doesn't work, you can do a repair install of Windows XP by booting off of that same CD. It's a good idea to be offline while doing this. Same for installing SP2 from the file you downloaded earlier.
What's troubling me is, how did the files get that way? Or what's causing XP to act that way? You may have an infection on your hands. A repair install will restore the system files to their original settings, but if your machine is still infected, it might not stay that way for long.
__________________
-Chris
My Website
Churnd is offline
Old 02-22-2006, 12:22 PM   #12 (permalink)
Cebby's Avatar
Ran the sfc /scannow and it seemed to change a number of files (when hitting the start menu, a bunch of "new" stuff appeared to be installed).
I discovered that my wife managed to shut off her virus software somehow, so I did a fresh scan. (PC-Cillin). It found 35 Trojans. Tried the sfc /scannow deal again.
Then I ran the SP2 upgrade. Same error in the exact same place. WTF.....
Next step is to try the repair install tonight.
__________________
UZswap.com
My 4Runner
TOOLandFAB.com
Cebby is offline
Old 02-22-2006, 06:27 PM   #13 (permalink)
DudeBud's Avatar
Send a message via AIM to DudeBud Send a message via MSN to DudeBud
maybe its something to do with your avatar
__________________
Dan
95 4runner 3vze A/T
84 4runner sr5 Ford 302
T-18 4spd yota t-case
yota front and rear both open
37X13.00 boggers
88 4runner 22re 5spd
DudeBud is offline
Old 02-22-2006, 06:51 PM   #14 (permalink)
Cebby's Avatar
I was thinking of replacing my avatar anyway. How about this one:
__________________
UZswap.com
My 4Runner
TOOLandFAB.com
Cebby is offline
Old 02-22-2006, 10:59 PM   #15 (permalink)
photoleif's Avatar
Send a message via AIM to photoleif
about word and outlook, it sounds like you might have word enabled as your e-mail editor. it does a plugin to outlook if you enable that. go disable it and see if that helps. also, the document template ( .dot) file that represents the e-mail starting state may be corrupt given the macro that tries to run. that *might* be related to the trojans you had, or it could be something else. you might want to refresh that install as well, while you're at it with SP2.
and...speaking of SP2, the 'access denied' almost always means it's trying to replace a file that's in use by a process that it can't abort. just shutting down the active apps may not be sufficient, if you have a lot of things that run on startup, such as services. some of them will spawn other programs. if you're really gung ho on getting up to SP2 (and everyone should, given the raft of security problems facing you in SP1 or earlier), you might want to just safe-boot with no network, and run the install that way.
__________________
'95 Xtra cab 3VZE SR5V6 | 33x10.50-15 BFG AT/KOs | 4" Superlift | OME torsion bars | Total Chaos idler arm and uniball | Rancho steering stabilizer | Smittybilt front & rear tubular bumpers | Sportsman topper | Aisin hubs | Dual Optimas | Extended diff breathers | Custom center console
sometime: rear locker
some sometime: retire the IFS
My truck page
Photography:
http://www.aspen-graphics.com
photoleif is offline
Old 02-23-2006, 06:10 AM   #16 (permalink)
Cebby's Avatar
I forgot about safe boot. What's that F8 or something?? I'll try that also.
The Trojan issue is on my wifes machine, but we both have the Outlook issue.
In a nutshell, it says the certificate has expired. Sure enough, it has (from Microsoft) way back on 1/25/2005. I would think this is something that windows update would fix, no? It hasn't thus far - and my machine is running SP2 and it claims no "Ofice" updates are needed.
__________________
UZswap.com
My 4Runner
TOOLandFAB.com
Cebby is offline
Old 02-23-2006, 07:34 PM   #17 (permalink)
DudeBud's Avatar
lol nah this one
__________________
Dan
95 4runner 3vze A/T
37X13.00 boggers
DudeBud is offline
Old 02-23-2006, 07:56 PM   #18 (permalink)
Cebby's Avatar
Oh man oh man... Back to the refs?
__________________
UZswap.com
My 4Runner
TOOLandFAB.com
Cebby is offline
Old 02-23-2006, 08:02 PM   #19 (permalink)
photoleif's Avatar
yeah, F8 right after the black screen (unless you have some zipzowie video card, peripherals with secondary BIOSes, etc.) -- then be sure to do safe mode (w/o network) to try to get as few random extras running as possible. if you still have the problem, it's time for surgery -- time to start disabling processes, unregistering DLLs, and all sorts of fun for all.
__________________
My truck page
Photography:
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
XP SP1 Support Ends October 10, 2006 BT17R Computer Talk 1 08-17-2006 05:22 PM
Problems with XP SP2 uninstall callmej75 Computer Talk 4 07-22-2006 11:12 AM
XP SP2 with Western Digital 320Gig external HD Probs... Tim-in-TX Computer Talk 10 07-11-2006 10:23 AM
Windows XP SP2: Be Advised! kronicx Computer Talk 62 09-06-2004 07:19 AM
Windows XP SP2 released sabre Computer Talk 8 08-09-2004 10:27 AM
2009 InternetBrands, Inc.
