Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
EMERGENCY: does garmin venture cx have a key lock. mine wont power on!
Im away from home on a little adventure (iron man in louisville ky) and have very limited access to the internet.
I grabbed my Garmin etrex venture cx yeterday and (after using it hours before) It wouldnt turn on. I changed the batteries twice and left them out for 10hrs to try to reset it. Still nothing the unit is onle about 8 months old. Is there a key lock function or something on these that I accidently enabled? Is there a sequence to disable it.....or is this thing garbage Any QUICK help would be great, thanks guys.
__________________
poop 1988 stock 4runner, v6, 5spd, soft top. 1990 fj62 stock and mint! 1992 4runner, 3.4, auto, SAS'ed, Marlin USA springs (4"/5"), 37" PBR's, 30 spline Longfields, Hydro assist, dual inchworms (5:1, twin stick, 23 spline, chromo output, 10* clock) 5.29's, lockrite's, custom exo, custom snorkle, High angle drivelines drive shafts, 108" wheelbase, Warn hs9500i, Electronic shifters by AWshifting, Mcintosh/Dynaudio a/v system. The build up...http://www.yotatech.com/showthread.php?t=74915 |
| Sponsored Links |
#2 (permalink) |
well im back, Now I can do some research of my own. If you have any ideas post em or delete this thread.
__________________
#3 (permalink) |
If there is an odd ball power on disable feateru it probalby will ONLY be resettable if the power is supplied via the mini usb int he back...
Did ya use NEW "alkaline" batteries that actually have a charge? |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| emergency brake light wont shut off after lift install. | TRDrunner | 95.5-2004 Tacomas & 96-2002 4Runners | 13 | 04-24-2007 07:30 PM |
| Doors don't lock when key is turned... | GregStevens | 86-95 Trucks & 4Runners | 21 | 03-07-2007 08:28 AM |
| Lug nut lock key | OSU4Runner | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 12-30-2006 08:22 PM |
| turn key once wont try to start try secound time it will | marke | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 02-12-2006 08:03 AM |
| Key/Ignition Lock Cylinder Replacement | MSH1 | Maintenance & Repair Archives | 1 | 07-14-2005 10:37 AM |
