onboard rock camera, Video thread ? Where do you get bullet Cams?
So what are you guys doing for bullet cams ( lipstick cams) ?
I have an Awesome Cam, but was hoping on a Wide Angle and some feedback- (specs)
looking for a WIDE Angle bullet Cam.
Project ROCK CAM
Rig: 85 4Runner
I am going to wire in 2 bullet cams under my rig. Front view & Rear view.
sometimes want that extra help, when the Spotter Sucks or I lost my place
I bought this AWESOME Color bullet camera $180. a few years Ago to get on board Video of my street luge racing. ( runs on 8 AA Batteries) the color Picture is DVD Quality ! plugs into my Sharp ZR85 Dig Camera ! it works great, So will re use the system. but need Another bULLet Cam
1- I will wire up the Rig so I just Plug my camera AV jack into the AV Cam cable and then Plug it into a New Wired jack into switches in the Console of my 85 Toy (near the Stereo)
Switch 1(front cam) Switch 2 (rear cam)
2- For a Monitor Screen I will just use my Canon camera screen 2.5" .
(too much $$$ for a TFT Screen, Although you can buy 7" screens for as little as $80. ( not sure where I would put it) I have not found a low priced screen with Video IN jack.
3- Mount camera mount next to the dash and stereo using old school CD player mount flex pole thing.
4- Build a Quick disconnect for the two cams on my T-case Cross member ( this is well Protected, centered in vehicle and close to the cab, (less wire) [/
I will post up info and Pictures if this site will allow Pictures.( help on this ?)
( this is an Excellent Cam) I have used this Across the WORLD, taking on board Video on my Street Luge--> 1/2 off the ground at speeds of 70+ Mph.
Bullet Cam SPECS
Sharp 1/4" High Resolution HAD CCD sensor generating 400TV lines (TVL) of resolution with a 0.5 Lux @F2.0 and automatic gain control
EIA: 768X494, CCIR: 752X582 (HxV)
S/N Ratio: > 48 db
Electronic Shutter: EIA: 1/60s - 1/100,000s, CCIR: 1/50s - 1/110,000s
Scanning System: Interlace (2:1)
Gamma Characteristics: 0.45
Lens Details: Board Lens 4.3mm @ f2.0
Synchronous Output: Internal, Negative Sync.
Video Output: 1 Vp-p / 75 OHMS
Power Requirements: DC 12V / 150 mA
Temperature Range of Operation (deg. F): 14 - 122
Project ROCK CAM
Rig: 85 4Runner
Bullet Cam SPECS
S/N Ratio: > 48 db
94ofCanada
08-14-2015 06:37 AM
priest16
15
08-06-2015 07:43 AM
Suprarossa
07-06-2015 05:21 AM
