onboard rock camera, Video thread ? Where do you get bullet Cams?
So what are you guys doing for bullet cams ( lipstick cams) ?
I have an Awesome Cam, but was hoping on a Wide Angle and some feedback- (specs) looking for a WIDE Angle bullet Cam. Project ROCK CAM Rig: 85 4Runner I am going to wire in 2 bullet cams under my rig. Front view & Rear view. sometimes want that extra help, when the Spotter Sucks or I lost my place :con: I bought this AWESOME Color bullet camera $180. a few years Ago to get on board Video of my street luge racing. ( runs on 8 AA Batteries) the color Picture is DVD Quality ! plugs into my Sharp ZR85 Dig Camera ! it works great, So will re use the system. but need Another bULLet Cam 1- I will wire up the Rig so I just Plug my camera AV jack into the AV Cam cable and then Plug it into a New Wired jack into switches in the Console of my 85 Toy (near the Stereo) Switch 1(front cam) Switch 2 (rear cam) 2- For a Monitor Screen I will just use my Canon camera screen 2.5" . (too much $$$ for a TFT Screen, Although you can buy 7" screens for as little as $80. ( not sure where I would put it) I have not found a low priced screen with Video IN jack. 3- Mount camera mount next to the dash and stereo using old school CD player mount flex pole thing. 4- Build a Quick disconnect for the two cams on my T-case Cross member ( this is well Protected, centered in vehicle and close to the cab, (less wire) [/ I will post up info and Pictures if this site will allow Pictures.( help on this ?) ( this is an Excellent Cam) I have used this Across the WORLD, taking on board Video on my Street Luge--> 1/2 off the ground at speeds of 70+ Mph. Bullet Cam SPECS Sharp 1/4" High Resolution HAD CCD sensor generating 400TV lines (TVL) of resolution with a 0.5 Lux @F2.0 and automatic gain control EIA: 768X494, CCIR: 752X582 (HxV) S/N Ratio: > 48 db Electronic Shutter: EIA: 1/60s - 1/100,000s, CCIR: 1/50s - 1/110,000s Scanning System: Interlace (2:1) Gamma Characteristics: 0.45 Lens Details: Board Lens 4.3mm @ f2.0 Synchronous Output: Internal, Negative Sync. Video Output: 1 Vp-p / 75 OHMS Power Requirements: DC 12V / 150 mA Temperature Range of Operation (deg. F): 14 - 122 |
