Trail Gear diff armor installed...
Big props to Josh at Tubingworks, Mikey, and Andy for getting my diff armor on while I was stuck at work..
Cant wait to bash them on some rocks!!
Had fun prepping 'er for the fitment and weld. I did notice your spare was pretty freakin loose though when I grabbed it to get out from under the Toy. Just a thought. Those diff covers are burly.
Not doing anything with the drain plug except installing the low profile plug that comes with the armor...
Note to anyonme buying this armor....it does require some grinding to fit right.
Is there anything else you can do with the drain plug? I beat the heck out of mine a couple of weeks ago and had to grind it down on the sides to fit the socket.
More info:
http://www.4crawler.com/4x4/ForSale/AxlePlate.shtml
Even the low profile plugs will get bashed up and knocked loose on the trail. I see one knocked loose every couple of wheeling trips I go on. Cheap fix is just to weld them into place.
XtraCab
04-12-2020 05:25 AM
jerusry
10-19-2015 05:28 PM
Backcountry411
07-24-2015 08:06 AM
