Relocating tcase Cooler ?
For those of you that had to move your Tcase cooler to make room for the passenger side spring tube where did you wind up moving the cooler to?
Pictures would be great.
Thanks
Thanks
Yota's with the A340H use some funky hydralically controlled transfer that utilizes a small cooler that is mounted low on the passenger side frame rail, right about where the shackle would be located when doing a SAS.
Relocating it should be as easy as making some longer lines, or extending the stockers, and sticking it somwhere under the hood. You might also be able to stick it behind the transfer case tucked up to the body. It shouldn't be too hard to mount with a couple of strong zip ties or sheetmetal screws.
Can't find anyplace to move it within the hoses reach. I need to either extend the hoses or get longer hoses, not sure of the fittings and where to get a longer hoses. Any help would be apreciated. Can post a picture tonight.
Thanks
If you have to move it, I would take this chance to upgrade it. Wheelin can be hell on an auto tranny. I am putting a monster cooler with its own fan on my A340H.
Here is a picture of the cooler that I am talking about
I looked in the FSM but couldn't find any referance to the tranny/TC coolers.
44Runner is this the cooler you are upgrading? Any info on the upgrade you are getting would be great.
Thanks
Thanks
I will be running something along these lines for the tranny:
http://www.jegs.com/webapp/wcs/store...0631&langId=-1
kawazx636
10-06-2021 03:03 PM
TheBFA
02-15-2020 06:55 AM
scott90
10-04-2015 09:21 AM
hiluxinargentina
09-30-2015 05:51 PM
JookUpVandetti
09-30-2015 08:58 AM
