Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
Co-Founder/Administrator
Staff
Hi Lift carrier spare tire on FJ Cruiser
I wonder if something like this can be fabbed up or not to work with the FJ Cruisers spare tire?
I have Slee's Hi Lift mounts on my roof rack now. But dang, the roof is so darn tall on this rig, much taller than my 4Runner was where I could reach the Hi-Lift with ease. I need to use a 4' ladder to wash the roof on this new beast. I am thinking of using the mounts up there instead to put my old shovel up there. It would be much easier to have the Hi-Lift on the spare tire like in the first photo. If there is not a commercialy available one now for the spare tire, you make it, I will buy it.
__________________
Corey 2007 FJ Cruiser ARB bumper, Warn XD9000, OME lift, roof top tent, so much more, see my website & buildup thread PNW FJ Cruisers ☺ Detailing 101 ☺ Join Topsites ☺ Muffler Comparisons ☺ Maggiolinas In The Wild FJ Cruiser Buildup ☺ New Roof Top Tent ☺ Video Of My Penthouse ☺ Rehinge Your ARB/Engel Fridge |
| Sponsored Links |
#2 (permalink) |
How about a pic of your spare tire mount (how the tire mounts to the carrier). Those wheels are still 6 on 5.5 right?
A pic without the center cap on the wheel (if so equipped) while on the carrier would help...
__________________
UZswap.com A site dedicated to sharing info for swapping the Toyota/ Lexus UZ (V8) engines into Toyota Trucks and 4Runners. My 4Runner 1993 4Runner, 1UZ (V8) auto dual ultimate crawler, double locked, 35's on beadlocked SR5 alloys, low lift, hacked fenders, tubbed firewall, custom armor TOOLandFAB.com A discussion forum dedicated to tools, fabrication & workshops. See my JD2 Bender Hydro Conversion |
#3 (permalink) |
Are you wanting to put this on there full time or only for trail use?
I ask because there is a way to do it, that isn't too secure. Wouldn't be good if you were going to leave it on there all the time.
__________________
IFS SAS My mods aren't bling enough for the signature line. -All Terrains are for when you know how to drive. |
#4 (permalink) |
Also a pic without the tire on the carrier would be good...
I have an idea that I think will work well...
__________________
#5 (permalink) |
Sponsoring Vendor
Buy the KayMar HiLift mount and add it to your FJ tire carrier. Don't see why it wouldn't work. The sell it seperate.
__________________
Phil Toyota & TRD Parts Wholesale www.FJCruiserOffroad.com www.trdparts4u.com www.toyotapartsales.com Authorized ARB/OldManEmu Dealer Authorized OASIS Air Deflators Dealer |
#6 (permalink) |
Staff
Mike, no pics of the tire here, but I am sure I can dig some up later.
Axle, it would only be when going on a run. Phil, will have to read up more on the Kaymar one. I have the ARB catalog in the cab of my jitney here at work, I will grab it before I get off work. I just can not see hefting that thing up onto the top of my rack. A shovel, yes. I can stand on the passenger side rear tire to access something light weight like my fiberglass shovel. In my younger days hefting a Hi-Lift that high might not be so bad.
__________________
#7 (permalink) |
Sponsoring Vendor
Man-a-fre sells KayMar. Check out his site. Good people and fair prices.
__________________
#8 (permalink) |
Mike is right, something that uses the lug pattern and has a bit of a stand off should clear fine.
I am a pretty big animal, throwing something of that size and almost significant heft that high is not something I enjoy doing. I am also a proponent of having the jack outside on a bumper so it is easy to get to. On the Ultimate Adventure it took 4 trucks to find a jack that wasn't going to require half the day to get out and use. At that point I am going to lay under the truck and think dirty thoughts. ![]()
__________________
Ease on down the road. |
#9 (permalink) |
Staff
I am thinking something again...
I have seen them mounted to the ARB bumpers up front, I may end up doing that. Less stress on the rear door hinge, and laying down flat would be less stressful too. Adrian, you are tall and big ![]() If you have a chore throwing a jack up that high, well heck, I might need a crane. I could see doing it from the side of the rack using Demellos mounts, but I do not want to fork out $90 for those right now. But from the side of the rack to the top is totally different.
__________________
#10 (permalink) |
Staff
I called up ARB since they handle Kaymar stuff as in the spare tire Hi-Lift carrier, and they said Kaymar has no plans to build one for the FJC.
However...ARB has in the works a rear bumper for the FJ, as they shipped an FJ over to the land down under two weeks back. I am sure some of you have heard this through the rumor mill before. Well, the bumper will have a Hi-Lift mount in it, and probably a swing out gate for the tire also. I am holding out for this new bumper. It sounds like it is going to be sweet.
__________________
#11 (permalink) |
I had mine on top of the ARB with studs. I really liked it though it was only that way for a couple trips. The bumper lives on with AxleIke, not sure if he has used the studs yet.
I am a big dumb animal some times. 48's are right at the limits of what I care to hump around. With the 60, you have one choice and that is where I am leaving it.
__________________
#12 (permalink) | |
Staff
Quote:
Heck, with it I would not even need the jack ![]()
__________________
#13 (permalink) |
I have mine mounted on top of my ARB Prado bumper using wheel studs from a heep and 2" bodylift blocks. Got the idea from zman2day.
__________________
1985 4Runner Dual e-lockers, dual cases, yada yada '00 Suburban 2500 4x4 '07 Tacoma Double Cab 4wd TRD '02 Lexus IS300 1991 Tiffin Allegro 31' Class A Last edited by dragr1 : 09-01-2006 at 09:44 PM. |
#14 (permalink) |
Here is the bumper in question:
![]() A shot thats a little closer, you can see the stud, it is just welded onto the bumper: ![]() I have not used these. I have the jack on the roof, cuz I leave it on. I am getting a 60 so i may switch to the bumper mount then, as it will likely be pretty heavy.
__________________
#15 (permalink) |
Staff
Phil, I have confirmed the bolt pattern is 6 on 5.5 for the FJ Crusier.
I see Man-A-Fre has several of the Kaymars, so it gets confusing. http://man-a-fre.com/parts_accessori...chmentsacc.htm
__________________
#16 (permalink) | |
Staff
Hey, Man-A-Fre just got back to me.
They would need an FJ Cruiser to pop on in to their shop, then they can test one of the Kaymar Hi-Lift mounts since there are a few models. Quote:
__________________
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Spare tire carrier | gametom | The Fab Shop | 4 | 05-20-2007 05:34 PM |
| spare tire carrier | malinjj | Items Wanted | 0 | 05-11-2007 03:47 PM |
| Spare tire Carrier Removal?? | toyota884runner | 86-95 Trucks & 4Runners | 4 | 12-01-2006 12:43 PM |
| spare tire carrier | boats | Axles/Suspensions/Tires/Wheels | 1 | 02-28-2006 04:11 PM |
| spare tire carrier ? | Ric | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 04-06-2003 10:22 AM |
