1984 4Runner Shackles - Nothing Fancy - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps > The Fab Shop
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-11-2007, 06:04 AM   #1 (permalink)
04 Rocko Taco's Avatar
Send a message via AIM to 04 Rocko Taco Send a message via Yahoo to 04 Rocko Taco
I copied this thread from my post over HERE
I decide to make some lift shackles for 1984 Runner. These things are 8" between the holes (2.25" lift) and they are pretty freakin big, I think if they sit weird or anything, I will cut them down to 6" (1.75" of lift), which is the biggest size, I could find commercially available.
I started with some 1/4" X 1.5" Steel Flat Stock. I then measured for the holes, added about a 1/2" to each end for strength and cut them out on my angle grinder with a thin (.045) cutoff wheel. I then took them over to my drill press and drilled out the 1/2" holes for the bolts, I then took them back to the angle grinder and bench grinder (and wire wheel) to round off the edges, and soften up the look a bit, and then painted!
I'll let the pics explain better...
Let me know what you think.
Cutting them out of the stock... (NOTE: See the "Safety Goggles" - Proto Anti-Fog Competition Anti-Glare Paintball Mask. lol)
Drilling out the holes... (NOTE: David, you know you want the drill press)
Grinding them round...
Finished?...
Painted!
Now, I just had 6 more to do...
And all it took was these simple tools...
(Note the OME struts in the rear right, and the OEM 4Runner Coils in the rear left. Pack Rat!!)
Thanks for reading, let me know what you think.
Just for comparison sake, I am posting the measurement of the center of my fender wells, (from ground through hub, to fender) from before and will post the results once they are installed.
BEFORE:
Front Driver - 35.25"
Front Passenger - 35.25"
Rear Driver - 32"
Rear Passenger - 32.25"
__________________
-Chris Tread Lightly!
04 Double Cab PreRunner. 3.4 - Auto
84 4Runner 4WD. 22R - 5 spd Lifted, Locked, 33x12.50
Disclaimer:My Photobucket is being revamped. If there are broken links, shoot me a PM. Thanks. ~Chris
Great Toyota Tech
04 Rocko Taco is offline
Old 10-11-2007, 06:13 AM   #2 (permalink)
jagger_snitt's Avatar
Those shackles look great and you never know about those stray paintballs!
__________________
"The Black Death" (DD)1988 4Runner 22RE 5Spd,StreetRvHead,261c Crawler cam,hi-output alt,35" BFG MTs,Optima Red Top. SAW 25mm T Bars,4Crawler BJ spacers,Tuff country 3" add-a-leaves,4.88 gears.Need 7.5 4.88 gears/thirdmember! PM ME!!!
"The Silver Death"1987 4Runner SR5,22RE 5spd,4Crawler Short Throw Shifters T-cases and 5Spd,SAS,MC Dual cases,4.88s and detroits front and rear,Allpro Tripple-X transfer case mt w/drivetrain E-brake,TG rock sliders,3"susp,3"body.35" Maxxis Big Horn MTs
jagger_snitt is offline
Old 10-11-2007, 08:28 AM   #3 (permalink)
Okay guys.... what do we think about bracing these? They are pretty long... I have a couple of design ideas, but lets hear yours...
__________________
Great Toyota Tech
Old 10-11-2007, 08:35 AM   #4 (permalink)
Kaleb's Avatar
Send a message via AIM to Kaleb
I would have used thicker metal.
X2 on bracing.
__________________
MY BUILD
Kaleb is offline
Old 10-11-2007, 09:12 AM   #5 (permalink)
4Crawler's Avatar
Yes, I generally use 3/8"x2" flat bar for my shackles. I recommend bracing them when 2" longer than stock, especiall up front, for stability:
- http://www.4crawler.com/4x4/ForSale/...es.shtml#FAQ11
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 10-11-2007, 09:54 AM   #6 (permalink)
CJM
CJM's Avatar
You seem to have never drilled metal, reason I say this is b/c your smoking the bit and ruining the temper of the metal. Use lubricant, I like pb blaster or plain old motor oil. Not knocking ya, just some good FYI..
Also I woulda used thicker metal too and brace them.
__________________
96' T100 SR5 4x4, ISR mod, Custom ABS snorkel, KC 57's Hella optilux el cheapo backup lights. Cobra 19III CB, Firestick 4ft antenna, Bilstein shocks.
Be polite. Be professional. But, have a plan to kill everyone you meet.
CJM is offline
Old 10-11-2007, 09:58 AM   #7 (permalink)
jjrgr21's Avatar
why would you use a penetrator for drilling. and its supposed to smoke when using a lube. i've got some kind of wax the local machine shop guys gave me and it works pretty good.
__________________
2003 4WD TRD Tacoma
1986 4Runner
jjrgr21 is offline
Old 10-11-2007, 10:02 AM   #8 (permalink)
CJM
CJM's Avatar
Quote:
Just cause its what I had laying around, penetrator oil seemed to work fine. I have had drills smoke, but not like that. I take my time, my grandfather taught me to take your time, if it begins to smoke you need to back off a bit and let it be otherwise you can ruin the metal or the bit easily.
I trust a guy who has been a machinist for most of his adult life.
__________________
CJM is offline
Old 10-11-2007, 10:07 AM   #9 (permalink)
Send a message via MSN to Greg_Canada Send a message via Yahoo to Greg_Canada
I always heard if you take youre time you'll ruin the bit, so u have to put some pressure on it and "help" it cut. Dont just let it sit there and heat up. Seems to work good for me.
__________________
http://www.cardomain.com/ride/1147271/1 My 1989 Toyota 4runner
Greg_Canada is offline
Old 10-11-2007, 10:15 AM   #10 (permalink)
Nice Chris, now lets see the comparision pictures. I'm very interested to hear what you gained off-road.
SLC97SR5 is offline
Old 10-11-2007, 10:16 AM   #11 (permalink)
CJM
CJM's Avatar
Quote:
Well not take your sweetass time, just dont make the thing violent smoke is what I was told.
__________________
CJM is offline
Old 10-11-2007, 10:18 AM   #12 (permalink)
Thats WD-40 smoking, not the metal, or the drill bit, I had a little tiny bit of 3 in 1 machine oil I started with, but WD40 is all I had to finish up. lol. Thats what is smoking.
__________________
Great Toyota Tech
Old 10-11-2007, 04:17 PM   #13 (permalink)
Adam F's Avatar
Send a message via AIM to Adam F
Also running your drill press at a lower speed helps with cutting metal.
Adam F is offline
Old 10-11-2007, 04:54 PM   #14 (permalink)
Kaleb's Avatar
I've never seen a bit smoked without lube. Bits can only smoke with lube. This is because there is nothing to burn when you are drilling metal. You can smoke a bit drilling wood fairly easy, but not metal to metal.
__________________
MY BUILD
Kaleb is offline
Old 10-11-2007, 04:58 PM   #15 (permalink)
CJM
CJM's Avatar
Quote:
Musta been the drill bits or something, cause they heated up without lube and smoked like nuts.
__________________
CJM is offline
Old 10-11-2007, 05:41 PM   #16 (permalink)
Quote:
Yeah had it down to 620 RPM, thats the lowest spindle on the drill press.
__________________
Great Toyota Tech
Old 10-11-2007, 08:22 PM   #17 (permalink)
Super Moderator-Sponsoring Member
Staff
waskillywabbit's Avatar
Send a message via AIM to waskillywabbit Send a message via MSN to waskillywabbit Send a message via Yahoo to waskillywabbit
HSS drill bits...I use them all the time dry and at the proper rpms no need for lube.
How much lift you trying to get out of those shackles? I got a set of 3" lift shackles sitting on a shelf somewhere collecting dust.
I would use 3/8" plate as well...as 1/4" is just too flimsy.
waskillywabbit is offline
Tags
1984, 1988, 4runner, 84, build, city, forums, lift, oregon, runner, shackle, shackles, shifter, short, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Outsane's 1984 4runner Outsane 4Runners-1st gen 8 10-09-2009 09:03 AM
1984 Toyota 4Runner idayota The Classifieds GraveYard 5 07-30-2008 12:22 AM
Installed the HELLA500s on the pickup..nothing fancy Tacoma750 86-95 Trucks & 4Runners 30 09-27-2007 07:45 AM
1984 1/2 4runner Build UNO_Student Offroad Tech 1 09-25-2007 08:33 AM
2009 InternetBrands, Inc.
