Vendor Advertising Vendor's, use this area to alert members to your OEM & Aftermarket Toyota parts
Recovery Points
Old 10-16-2012, 05:58 PM
maxxmaven's Avatar
Recovery Points
Check out these recovery points for the 80 and 100 series land cruisers.
URB's- Universal Recovery Bracket, fits front and rear factory locations.
www.jonesysoffroad.com
Old 10-16-2012, 06:05 PM
maxxmaven's Avatar
Recovery Points
Check out these recovery points, they fit 80 and 100 series land cruisers. Mount directly to the factory bolt holes. URB's-Universal Recovery Bracket.
Old 10-16-2012, 07:32 PM
warpigg's Avatar
its just a shackle mount i could make one of these i dont see the hype
Old 10-16-2012, 08:06 PM
maxxmaven's Avatar
They are made of laser cut 1/2" steel, bent/ welded and powder coated. Maybe you can make these but, not everyone can.
Old 10-16-2012, 11:20 PM
warpigg's Avatar
all you need is a steel place to cut and bend the peices then anyone can weld them and then just paint them. how much do these cost, because with the price of steel and bending its only like $15 each
Old 10-17-2012, 05:37 AM
Fossilized
Staff
dropzone's Avatar
duplicate threads merged and moved to vendor
Old 10-17-2012, 08:00 AM
snobdds's Avatar
Who taught you how to run a winch line...that crossing of cable is downright scary!
The proper way would be to have double recovery points on each side of the frame connected by rope/wire in a triangle to a snatch block, and then the winch should be connected to that. That way you’re not pulling on only one side of the frame.
Armatures...sheesh.
Old 10-17-2012, 11:09 AM
Fossilized
Staff
dropzone's Avatar
just had a chance to watch the video-
per the rules post a location and price or thread gets deleted.
Old 01-01-2013, 12:01 PM
maxxmaven's Avatar
You find them here at; www.jonesysoffroad.com
Old 01-01-2013, 12:56 PM
Discombobulated's Avatar
Someone's not very bright.
buckz6319
08-05-2017 03:50 AM
83yotastockR
11
11-10-2015 06:54 AM
Obmi
10-04-2015 11:30 AM
beltcutter
09-30-2015 06:14 AM
JPV
09-28-2015 03:15 PM
Quick Reply: Recovery Points
